Quilt frame and a front
I've been asked to build a quilt frame that will reside in the Middle/High School building. The auditorium and the cafeteria are nearby.
They want the quilt to be enclosed and the frame to have a transparent front.
I tried selling them on glass, but they have concerns w/ it (even if it is tempered). So they want "plastic".
I can get sheet acrylic or polycarbonate in the correct size.
I was thinking about using 3/16" as it is a bit more rigid and less flexible.
I am leaning towards polycarbonate as it is a bit tougher and less likely to yellow upon exposure to UV light. The frame won't be in direct sunlight, but it may catch some reflected light.
Thoughts?
Re: Quilt frame and a front
Re: Plastic
The softer poly-carb is more durable to impact but it scratches pretty easily. Acrylic has a harder surface and is unlikely to have to withstand a significant impact, way cheaper as well.
Cheaper - not significantly
I would be purchasing a 8' x 6' sheet (cut to size).
Acrylic would be $350.
Poly-carbonate would be $375.
A Pitence
So that some frosh bouncing off the walls in the middle of a sugar rush doesn't do irreparable damage, I'd go with the Lexan ;)
Yonak
Did you say Middle School ? Use plywood.
Many years ago (40?) I built a trophy cabinet for the local school. I used laminated windshield type safety glass for the front. I had completely forgotten the case. I saw it a few years ago and had a flashback. The glass held up better than the rest of it. It was expensive and heavy.
William Duffield
I would be wary of using plexiglas. I have four panels of it in a screen door off my porch. The first time my dog tried to go through it, she put two cracks in it, in a "Y" pattern. Later, a squirrel got onto the porch, through another security breach. When the dog went after it, it tried to run out through the same panel. It successfully executed a Roger Rabbet escape, breaking out a squirrel sized piece of the cracked plastic by running headlong into it.
Most of them don't get out alive. This one ended up with nothing more than a really bad headache.
