Unknown Incra stash...value?
Tom Dunlap
Hi,
This is up for sale...seems worth $75 but I'm not familiar enough with Incra to know if any of this is complete.
Please let me know if you can ID any of the bits and bobs.
Thx,
Tom
Tom Dunlap
Hi,
Thx,
Tom
Depends on what you want to do.
Gary Smyth
for $75 you will be ok if you use list -- catalog prices as a guide. The red base Incra pencil hole protractor is $29. and the table saw miter gauge is at least $79 and some models (2000, 3000) list over $100. Other angle indicators and the saw tooth height gauge would kick it up some, There is also a consumer model table leg angle jig. The Incra gauge looks as if it is workable but hard to tell from the photo. Even if complete does it relate to the work you do? it will take lots of time to use it effectively and you may not have the time or inclination to learn. Depending on what you want to do in woodworking all included could be a good deal or just helpful. Better photo and model numbers would guarantee you comfort for your money. If you are considering just for the Incra jig you will need more research.
Re: Depends on what you want to do.
Don Evans
You can research for yourself at one of these two sites.
www.incra.com or www.incrementaltools.com
Re: Unknown Incra stash...value?
Mike Cutler
Yes, it is definitely worth $75.00.
I see various Incra rules, which are not cheap.
The Incra 2000 miter was pretty expensive new. IIRC about $175.00. It's a little bit of a pain to get setup, but once setup, it's built like a tank. I have that same model.
I can't tell which Tablesaw mounted Router Fence system that is, but all of them were $300.00+ new, by the time you got the first piece of wood through them. I can't tell if all the parts are there, but it looks basically complete. It's either the earlier version, or the micro adjuster is not there.
The Incra stops are currently 40.00 each new.
I see that angle jig, which is kind of flimsy, but on short stock it's OK.
That guided circular saw angle jig is useful on "rougher" projects, or to initially dimension wood.
You won't lose any $$$$ paying $75.00.
After work...
Tom Dunlap
...I'm meeting the seller with a wad or fivers.
Mike
Thanks for interpreting what's there. I muddled around the Incra site and gathered that the whole works seems a good deal. That is, if everything is there
I'll follow up later this evening
Tom
Bought
Tom Dunlap
We met at a McDonald's parking lot to close the deal. I asked...what's the bottom dollar? Saved a few too
Some of the pieces are useless to me...but enough are useful!
Now I have to go through the Incra catalog and find out what everything is used for.
Tom
Re: Bought
Jim Matthews
Hook rules are really handy.
If those are "spares" I would gladly adopt them
