OT calcified crud in kitchen sink/dishwasher drain
Dick Coers
Spent most of the afternoon yesterday with my head inside the sink base. The drains were slow and gurgling. The two drains connect inside the wall, so two drains, 2 traps. When I pulled the dishwasher side, I found about a 1/16"+ thick coating of hard calcified looking material. It took a pretty hard poke to break it loose from the PVC. Felt it inside the copper pipe in the wall as well. I put it all back together, and unfortunately it flowed slower. Ran to Menards and bought one of those drill powered 1/4" snakes. It took a while longer to pull it all apart, run the snake in and out multiple times, but the flow is now like new.
Every run into a hard coating like that? Of course I first grilled the wife on what the heck kind of drain cleaner she was trying to use. Not a smart move of course!!!!! Still haven't learned after 42 years, darned primitive male thinking! Then started thinking about the Finish brand power ball tablettes and dishwasher powder we are using. Can that solidify again? We used to run a cup of vinegar once and while in the regular dishwashing cycle to clean the hard water deposits in the dishwasher, that's going to start up again!
Rotten way to spend a Sunday afternoon! Literally!
Re: OT calcified crud in kitchen sink/dishwasher drain
Yes
Especially with hard water and too much detergent. Harder for detergent to completely dissolve and will stick to drain pipes and build up. We cut the d/w bricks in half. Even more important to prevent over sudsing and incomplete rinsing since putting in a softener.
d/w gets run empty with no soap once in a while.
Jim Hoeller
I have been using white vinegar in my coffee brewer to keep it clean and then pour the hot vinegar in the kitchen sink. It removes the mineral deposits and keeps the drain open.
John Veerkamp
it's a combination of fats, soaps and other "stuff" including calcium uniting to form the crud you describe. Vinegar will really only help on the bottom third of a horizontal pipe. Some of the enzyme drain treatments really help if used regularly. Also good for septic systems.
paul in AZ
I know a little something about hard water and dishwashing powder. My drain line from the kitchen began plugging up and needing rooting out every 6 months or so. The rooter pulled out fairly hard but crumbly white crud.
The dishwasher almost stopped draining out and replacing it's innards costing what it does I chose to replace it.
One of the rooter men told me to look at the dishwasher powder. Seems that several years ago the manufacturers quietly stopped making powders with phosphates. The new powder doesn't dissolve very well, specially in hard water, and begins to line the drains with what is headed towards becoming hard crud.
I gather that the new pouches of soap do dissolve. So far a couple of years without calling the rooter man.
We had trouble with the powdered detergents, too and have been using liquid Cascade ever since. Makes a big difference. The vinegar and enzyme treatments are also worth pursuing if you can be bothered with routine maintenance. It's a struggle for me.
Dave Bair
Why don't you guys with hard water get a softener? Not having to deal with mineral crud and water-heater longevity is well worth it (and you'll just love your next shower).
paul in AZ
Did that once. A long time ago in Mass., not here.
The softer water dissolved crud in valves and practically all of them throughout the house began leaking and had to be replaced.
Much less troublesome if done with new construction.
