A "Cheap" question....
Edward in Vancouver
Need to replace our kitchen cabinets, rather than rip out everything we discussed just replacing the doors. Wife loves the look of white glossy laminate, and I talked her into a plain maple edging aprox 3/16" thick around the door edges.
Current doors are mdf with a "frame and panel" pattern routed into it. I could toss out all the doors and start with fresh 3/4" ply, but I was thinking of reusing the existing doors.
-Option 1 would be to plug the hinge pockets on the backs of the doors and use this as the "show" face. After all, I'll be glueing down laminate on the surface.
-Option 2 would be to plug the routed channels as best as possible with spruce, and fill in the remaining gaps with drywall compound or similar, and use this as the show face.
What I'm concerned about is that I might get lines from the gaps telegraphing through the laminate in a few years time.
-Option 3 is to toss out the doors, and buy in a couple sheets of 3/4 ply. Getting rid of the existing doors will have some problems, and breaking down sheets will also have problems giving my space constraints.
Talking to a laminate supplier, I understand there are two thicknesses of laminate, and it is best to use the thicker, as any surface imperfections will telegraph through. I also understand that I need to laminate the backs of the doors or I will incur cupping.
Suggestions?
Edward
