Need some direction and advice. Looking at the Lumber Wizard IV sells for $139.95 and the Little Wizard Metal Detetector sells for $19.95. Do they work? Is the IV worth the extra money?
I haven't looked at the IV, but would suppose it has been improved somewhat.
Having a Woodmizer, for urban trees makes it necessary, and it has saved me some blades, but it does have it's limitations, and I do tend to saw plenty of large beams, which exceed the depth that it will read.
If I start to see any black in the wood, I can usually locate it, and dig it out.
When I'm not using it on the mill, it hangs between my 12" jointer, and 24" planer. If it keeps me from hitting a nail in either of those, it has covered it's cost.
Mike I have the Little Wizard detector. I don't a need to use it a great deal but it has helped me locate cut nails in old beams in the past. I even used it this year to find a nut that came off my post hole digger and landed in a pile of dirt. It's certainly a "lightweight" compared to its big brother but works well enough for my purpose. I would probably go with the better detector if you're working reclaimed or urban lumber.
