Re: Bugs in Oak questions *LINK*
Grant in Iowa
Hi Barry,
Odds are you are encountering Powder Post Beetle (PPB) tunnels. I will defer on the details to Bill, but it goes something like this:
I get them showing up in my air dried lumber from time to time before it dries completely. Even after it dries, the larvae will still mature and emerge as beetles to seek out a new place to burrow and lay eggs. Also, if you are seeing "frass", or little piles of fine sawdust under your lumber stack, it can mean the insects are active, or it can also mean the lumber has simply dried sufficiently to allow the powder to sift our as the pile gets banged during lumber sorting.... so don't panic.
So what I think you are seeing, assuming your lumber has been drying for some time, is the signs of the beetles emerging. The beetles are finicky about where they will lay new eggs, so once the wood dries below about 12% or so, they won't lay eggs in it any longer. Here in Iowa, due to very humid summers, I keep my dried lumber inside my air conditioned shop. I end up with a pretty even 10 or 11% moisture content in my lumber year around this way. This also helps keep the moisture content of the lumber similar to what it will be in finished form inside my air conditioned home.
Of course this is one very good reason to kiln dry your lumber. Kiln drying not only brings the Moisture Content (MC) low enough as to make the lumber undesirable to the insects, but the kiln operator can raise the kiln temperature high enough to kill any insects inside, though this is not always done.
If you store your lumber long term, do so off the floor as much as possible, and under cover in a drafty but not open building. Better yet in a modern building that is conditioned similar to a home.
Just because you have kiln dried lumber, doesn't mean it will stay below the moisture threshold, as that is more a matter of proper storage in a dry area.
I don't think it is a reason to panic, as they will naturally leave the wood once it dries, and the damage is already done when they enter the wood and lay eggs, so to speak. if you would like, there are products you can treat your wood with, such as Boracare, and others. I know Bill talks about dipping the stack of lumber in a product at the mill, but that requires the right setup to do.
I am by no means an expert, but I have been doing logs to lumber for around fifteen years now. I think lumber with PPB holes in it can add character to the right project, so I don't discard it just due to the holes. Sure, there are traditional furniture projects on which you would not do that, but there are plenty of other styles of projects that it can add a little something.
Here's a link to basic information about the subject
Regards,
Grant in Iowa
PPB's at Iowa state university
