Advice needed with new project
Ray Carson - Lawrenceville, NJ
My 16yr. old daughter owns a Bearded Dragon that she bought as a baby. In the past year it has grown rapidly and is about a foot long. It’s currently being kept in a 40 gallon breeder tank. ‘Mushu’ has a basking rock, a small tree and his water and feeding bowl also in the tank which doesn’t leave much room for movement or to do his “business.”
The plan is to move him into a 75 gallon tank where he has more room to move and to do his “business.”
My plan is to build a cabinet base that will also support the tank with fish once ‘Mushu’ has “moved on”. So the base has to be able to withstand a bit of weight in the future.
The tank measures 48 L x 21 x 18 h.
Its approximate dry weight empty is about 140lbs.
When filled with water it will weigh about 800 lbs.
With gravel, accessories, filter, etc. it could get close to 1,000 lbs.
My thought or idea was to build a sub-frame and wrap it in cabinet grade plywood with doors and some nice trim. I’ve already drawn up some plans placing posts at each corner and at mid span. The posts are currently sized at 2 ¾” square allowing for a band of ¾” material that will sit on a ¾” ledger or notch. This will form a table structure which will sit on a flat platform.
I would like to make the platform separate from the rest of the upper cabinet for ease of moving this in the future. If I build it as one unit, I think the weight will be too much to handle. The rest of the build is pretty straight forward.
Any input is greatly appreciated.
Thanks,
Ray
Re: Advice needed with new project
As long as the tank sits on the top of the posts, or effectively sits atop the posts, supporting the weight will be easily accomplished. Additionally, resistance to racking must be accomplished by mortise and tenon rails or rigid sides, etc. If the rails are supporting the tank then they must be robustly connected to the legs, or the floor through sides, front and or back.
I would probably start with a table with stout legs and mortise and tenon rails and decorate it from there. When the novelty of fish pass you will be left with a useful table.
Would'nt take a chance.
Gary Smyth
Why are you not considering a welded steel frame? Picture is a 50 gallon tank demonstration. Wood can be added as a skin to hide the chains and fire extinguisher until the actual dragon (0pps "Game of Thrones" thought) departs. After that, with a wood skin the innards can be used to hide filter material, pumps, food etc. for aquatic life. I'm sure that wood can be used, but I would take far more comfort with 1 1/2" steel tubing or angle braced top and bottom. 3/8 steel pads can be welded to support some hefty casters. Shelf brackets can be welded as necessary. With half a ton on top, and all or part capable of moving I'd be darn certain the bottom was strong and rigid beyond typical wood joinery. Not that it can't be done, but why?
Re: Would'nt take a chance.
I see your point Gary and believe me, I have considered the steel frame idea. I appreciate the input. I'm not taking any chances and I'm considering all options. If I went with steel, my problem is I'm not a welder. I have a few connections but making this out of steel drives up the cost.
Much regards,
Ray :)
The intent is to have the load come down on the legs or posts, not the rail. Six posts total. If I do my calculations correctly, this would place approx. 150lbs on each leg, or 25-30 per square inch. This seems feasible.
All joinery would be robust and stout. Bolted and glued with heavy duty adhesive if need be. When in doubt, make it stout.
Re: New project - PDFs attached.
Below my post are two PDFs with preliminary drawings. One is a top view of the "table". The other is a front elevation.
Yonak
Considering that a queen size water bed is three times the size and weight of your aquarium with about the same support as you're suggesting, I'd say you're on track. I agree with Bill that racking would be my concern. The "skin" may take care of that but cross-bracing or plywood sure would.
John McGaw
I think that any aquarium manufacturer would tell you that continuous support is required and that simply taking the weight on posts at the corners is a no-no. It really takes amazingly little to support an aquarium. The factory -made stand for my 100-gallon 6-foot aquarium is made entirely of particle board and has stood up very well to the half-ton placed upon it. Rigidity is really all that is needed when the load is placed edgewise on sheetgoods -- as long as there is no chance that it will rack it will take very little material to do the job.
Ray, my son and I have built a number of these over the years. (8 or 10) I have not look up poplar but I suspect it will hold something on the order of several thousand PSI in compression parallel to the grain. We built stands out of whatever we had. Pine, walnut, poplar, and salvaged pallets. Your posts are "beefy" enough so they will not buckle. If put rails under the edges of the tank it will spread the load better. If you Skin the exterior it will address the racking. You should have rails along the floor to spread the load over a broad area, unless it will be on a slab.
Give some thought to making the center post removable and the ends so you can open them. Several of my son's setups had large equipment down below and it was good to be able to remove or shift things a bit to get them into place. He has a setup in the basement that has four tanks of various sizes. Basically a rack built of construction grad 2x4's. Its asymmetrical. We had to offset the "center" post to allow for the arrangement of the tanks. There was some sagging without the post. It ain't perty but it works for production. The pretty one is the display tank in his room.
you will never get 6 to sit level on a typical floor. wood has huge strength in compression. 4 is satisfactory. There is several tons of weight on these vertical 2 x 4's
Re: 4 posts
I understand the theory of six posts vs. four but the "table" structure will be sitting on a flat base or platform. The PDFs in my initial comment shows this. I want six posts so there is support at mid span of the 48 inch long dimension. I don't want to rely on the tanks glass and cheesy frame to bear that load.
As recommened, I called the tank manufacturer and continuous support is recommended although not required. I'm going to error on the side of making the internal structure as strong as I can.
Sincerely, Ray
Re: Waterbed comparison
You know, this makes a lot sense. The weight of a waterbed is spread out but the theory is rock solid. Thanks Yonak.
Re: Rack
Thanks Barry. Based on your descriptions and the other comments, I think I'm on the right course. :)
Re: Particle board comparison
I looked at a lot of stands in the local pet stores and most are low quality, put together stuff made of particle board with MDF moldings. I don't like them or trust them but if they sell them to hold these tanks than I'm sure I can build something much more stout.
Appreciate the input John. :)
Re: Rack
Rich in High Ridge
It won't weigh over 1000 lb,s cause if you fill it with water the lizard will drown!
Re: Rack
Very funny. :)
Re: Rack
Rich in High Ridge
I think 140 lb.s might be a little on the heavy side but either way your only talking about maybe 200 lb,s total with tank sand and landscape .An average chair will easily hold a 230 lb + adult plopping down in it! your will be sitting still ! no engineering or over building neccesaryjust don't use particle board
Re: Rack
If you read my initial post, the stand is going to be built to hold fish in the future. That's why I'm building it so hefty. Sincerely, Ray
Re: Rack
Rich in High Ridge
well that makes more sense! you know you'll have to take the glass apart and reseal the tank if you do that
Re: Rack
Why?
Re: Rack
Rich in High Ridge
from all the reptile "waste" that contaminates the silicon and weakens the seal. you may get away with just resealing the inside and not taking the panels apart but I wouldn't risk it
Re: Resealing
No way. Really? I'll have to research that. Not doubting you but the lizard currently poops and pees on a indoor /outdoor carpet type material. It's not sand or anything like that. Interesting to say the least.
