TS Blade Sharpening Service
mdclor
I have been using a local sharpening service for the past 8 years but need a new one since we moved to VA. Can anyone suggest a local service or failing that one where I can send my blades? I used Forrest a long time ago, but I think they are pricey. Other suggestions? Thanks.
Re: TS Blade Sharpening Service
Dick Coers
I've had local services ruin blades. That's really expensive then. I send to Forrest.
Bart Goldberg
TS Sharpening Services
Bart Goldberg
If you dont mind shipping, I've had great success with Ridge Carbide in NJ
http://ridgecarbidetool.com/sharpening/
The Freud website *LINK*
DizD
has a "where to sharpen" link at top of page for an interactive map showing their approved sharpening shops. I just had a couple of blades done at shop in Summerville, SC and was pleased with results and price. YMMV.
http://www.freudtools.com
Joseph Mulherin, sr
If you would like to sharpen your own blades then go to Harbor Freight and buy their sharpening tool. Cost about $72.00.
I have sharpened 7 blades....7 1/2" ones and 2 10" blades. The one ten inch blade I did several months ago is still on the saw and is still sharp. The other 60 tooth blade is available when the 40 tooth blade goes sour.
Misenheimer
Misenheimer, Morristown, TN They do sharpening for area furniture industry and they make blades and cutters. I figure any palce that makes blades knows how to sharpen them. Alternatively fins a local shop and ask where they get stuff sharpened.
mdclor
I appreciate the replies. There are a few cabinet shops close by so I will stop by a couple to get suggestions. I will also ask about wood sources. The Freud site doesn't indicate any approved sharpeners in VA.
PS
It is the postage both ways that is pricey. Shops like Misenheimer will have a regional pick-up drop off route. Best is a shop you can just drop by, but there may be a regional shop that calls on the woodworking shops in the area and you could leave a blade there to be picked up and delivered back.
These shops may also weld up band saw blades and if they do the cost is half or less mail ordering from WW catalogs.
Also a large shop like Misenheimer sharpens router bits.
Bruce, a MN Galoot
Merle, our local Rocklers has an arrangement with a sharpening shop and serves as a drop-off point for blades, bits, etc. I've called the shop directly, and the prices are the same at both the shop and Rocklers. I'll bet there is a similar service near you.
mdclor
Bruce, there is only one Rockler in VA about an hour away. Of Course, the way the traffic is here in NOVA, that could be across the street on a bad day. :D Thanks for the suggestion.
Re: PS
mdclor
Thanks, Bill, I will ask about that.
Bruce, a MN Galoot
All of the sharpening shops are an hour away from home. Actually, everything is an hour from here.
I've been meaning to ask this: next time I'm in ABQ who am I supposed to go to lunch with now that you've moved? :) I hope you like Virginia!
mdclor
I used to have lunch with Jesse Cloud, John in NM and David Higgins (doesn't contribute here very often) every 2-3 months. It was always a good time.
Jim Hoeller
Quinn Saw in St Louis County does an excellent job on TS blades. They have state of the art CNC equipment and the costs are reasonable. I use a heavy cardboard box to mail them and the turn around is short. They have a website that is worth a visit.
