Spice Box- adding the berries
The plugs that will become berries are cut with the Lee Valley 6 mm taper plug cutter. This cutter is not ideal for the task. For a short plug, the plug diameter is significantly greater that the hole made by a 6 mm bit. I am having to chamfer the leading edge of the plug and drive it in.
After an array of plugs are drilled the plugs are sawed off with a band saw. I found it best to tape them. Without the constraint of the tape they fly all about the shop as they are released from the stock.
I made a template to mark the centers for the berry holes. Shown is a pin locating the hole center for the pattern of three berries. I don't try hard to exactly center the brad point drill in this locating hole. The result is some variation in berry spacing which can look better if not overdone.
Traditionally the berries were holly and cedar. I think the harder cherry works better.
