Low energy house question....
I would like to build a house that has very low energy consumption. Does anybody have a good source for reading on the topic? I used to build them thirty years ago. What has happened in the last thirty years? What is the state of the art now?
Re: Low energy house question....
Jason Roehl in Lafayette, IN
I've had a subscription to Journal of Light Construction for at least 15 years. There have been many, many articles on this topic over the years, especially in the last five or so years. I would suspect the same is true of Fine Homebuilding. I subscribed to that magazine for a few years, but dropped it because there was too much overlap between the two, and I felt that JLC had more "how-to" detail.
Maybe your local library has back issues. Or you can order a USB drive with all the back issues on it for under $100, I think.
Jason
Mark Nowicki
What happened is that people stopped caring about energy efficiency and started caring about granite counters and stainless steel appliances. That, and everybody needed 3500 sq.ft of living space with 1000 of those reserved for the pooch.
Probably the best way to save money and improve efficiency is not to use it in the first place, and build small.
I subscribe to Fine Homebuilding and to Canada Mortgage and Housing Corporation publications.
My money is on the CMHC.
http://www.cmhc-schl.gc.ca/en/co/grho/grho_020.cfm
Mark
Here is where to ask... *LINK*
John in NM
Personally I like SIPs, if I were to build another house, that is what I would use. Researching those is where I came across this forum.
green building forum
Jesper, Denmark
Jesper, Denmark
There are some very basic considerations: Minimum outside wall and roof areas for the contained volume in the house, Thick walls allows more efficient insulation and roof overhangs that allows maximum solar gain in winter and shades windows from the sun in summer.
Incorporate solar panels to make hot water (not large and simple to incorporate in design) and electric power (large, and requires some sort of power storage to cover all the electric power needs). Solar voltaic panels are simplest if you can send excess power back to the grid during the day and retrieve at night. Local battery storage is probably some years out in the future.
This gives a good general intro to insulation:
http://www.roxul.com/products/residential/where+to+insulate/contractor#/
walta
If you Google “net zero energy homes” the web will deliver days of reading.
I enjoy reading
http://homeenergypros.lbl.gov/
http://forums.finehomebuilding.com/breaktime/energy-heating-insulation
Before my library dropped it I liked reading this expensive magazine http://www.homeenergy.org/
A LEED platinum certified home will use very little energy but understand a lot of the points come from green hokum like giving point for building inside the city limits and recycled content in materials things that have no effect on a buildings performance.
http://www.usgbc.org/certification.
Walta
Jim Hoeller
I had a house built several years ago using "ECO-Block" and the house is all electric with geo-thermal heat. I heat and cool both levels (main floor and semi finished basement) with a total of about 3,000 square feet. The house is in a small village in the Missouri Ozarks with cold winters and hot summers. Average monthly electric bill is about $100 with the thermostat set at 75 degrees in summer and 72 in winter. Eco-block is a generic term for dense styrofoam forms that are glued together and filled with rebar and concrete.
Pallets would be great except for the bacteria
Jason in OC
One more magazine to check out is Home Power
http://www.homepower.com/
