Moisture trap for compressor?
Thomas E Norton
I would like to add a moisture trap/filter to my compressor. I see some at Harbor Freight and also Tractor Supply. Is they much difference in quality?
Thanks!
Re: Moisture trap for compressor?
Traps (rather than refrigerated "driers") do better the larger they are because they allow the air stream to expand and cool thus assisting in getting the water vapor to condense on the trap's walls. I've used HF trap/regulaters for 15 years on my system and they've done well
But
They're only part of what needs to be done. Getting water out of your compressed air starts at your compressor's drain. I have installed a Wilkerson auto-drain on my compressor that opens briefly and blows out the condensation that collects in the bottom of the tank. Once every cycle with a drop of 20 PSI the valve opens for several seconds. This does two things: 1st it keeps the water vapor level in the tank to a minimum. 2nd it helps retard rust and corrosion in the tank. In the photo you should note that the trap also has a drain which needs to be vented from time to time as does the drip-leg on the air line in the picture. I need my air dry as I shoot shellac and solvent lacquer as part of my finishing routine so water in the tank or the air line would really mess things up.
The auto drain is available from McMaster-Carr for about $70 and relieves you from the chore of manually draining the condensate water 3-4 times a week (depending on use). There are more expensive drains but the Wilkerson is simple and easy to install (you'll need some brass pipe and a few fittings).
Dick Coers
For any moisture trap to work well, the air needs to be cooled so the moisture can drop out. For some reason I remember a minimum of 25' away. No idea if that is a good number now. It just means mounting the trap as far away from the compressor as possible. It also helps to angle the line back towards the compressor, and have a clean out valve in a loop before it goes back into the compressor. Sorry, no experience with Harbor Freight traps. When I had a shop, I had a desiccant filter and paper roll filter in the spray booth for final trap before going to the gun.
Ooops
Part number is 4919K13 at McMaster but the price is now $87
mdclor
Tom, I made a heat sink from 1" pipe.
The long runs are 10' and it slopes down hill so the condensate will drain toward the valve. I also have a valve at the bottom of the tank that I open at the end of each day I use the compressor. This was in my previous shop and I intend to replicate it in the new shop.
Special Note
If you have an oil-lube compressor, you will extend the life of your pump by using synthetic compressor oil. However, doing so will limit your choices on regulators and filters and such because the carry-over oil in the air stream will attack the polycarb bowls in the filter/dryers. You'll need an all-metal filter housing if you use synthetic oil.
