Outdoor steps
Dave in Bryn Mawr
Am making steps for the front porch steps. What is the best wood for this?
Thanks!
Outdoor steps
Dave in Bryn Mawr
Thanks!
Re: Outdoor steps
Mark Nowicki
Teak.
Re: Outdoor steps
don stephan
"Best" depends on several things. If exposed to the elements, cypress, white oak, purpleheart, teak, epey, and treated yellow pine are long lasting. Cypress is quite soft, teak and epey quite expensive, and the latter two perhaps harder to work with. Don't know if today's mahoganies are weather resistant, mahogany was a traditional wood for boat trim.
There are several issues one might use to rank possible woods. Weather resistance, cost, workability, ability to hold paint, appearance under stain, . . .
Re: Outdoor steps
mdclor
I suggest black locust if you can find any or white oak should be readily available.
Re: Outdoor steps
Painted or not?
If you are painting it, I would recommended treated SYP. Easy to work with and relatively cheap. Don't compost the sawdust.
If you want to try other woods, I would suggest Ipe. Readily available and long lasting and not too terribly expensive.
use the wood to form up concrete
Dick Coers
I know, maybe not funny, but likely a one time build when using concrete.
