Made cut 2 short need help on best/easy/strong way
Ashley
Help I cut my boards too short and don't want to buy a new lumber. I need to know the best easiest strongest way to join these two any ideas and advice would be greatly appreciated as it sits now it is 12 2x6s laying horizontal attached with pocket screws and need to attach the 2x6 to end but vertical don't have any fancy tools to work with
http://media-cache-ak0.pinimg.com/736x/8c/fe/ab/8cfeabdfbeb301f99b27939f24d59bfa.jpg
http://media-cache-ec0.pinimg.com/736x/a4/7d/81/a47d8174c2f417a38661a09f2a13cc7f.jpg
Re: Made cut 2 short need help on best/easy/strong way
Ashley
Can't figure this pic posting out perfectly
Yonak
Ashley, not knowing anything about the usage or context of these pieces makes it difficult to give accurate advice. However, that won't stop me from giving it a shot.
You could run 2X4s spanning the top and bottom back edges of the panels and screw them to the 2X6s. Cutting a rabbet in the adjoining front edge of each panel prior to screwing together would let you attach a mating strip between the two, hiding the seam.
Re: using for
Ashley
I am so sorry about that and actually building a clubhouse / loft bed for full size mattress the wall is joined by pocket screws thinking this not give extra support also
