THE WOODRAT IS BACK!
OT Satellite radio Antennae connection Question
My little Sat. Radio has an antennae connection that plugs into it and you throw the magnetic gizmo on top of the car roof. This is the second time it has gotten to where it says "Check Antennae Connection" about once a minute. Last time I bought a new antennae (surprisingly expensive) and now its doing it again. If you wiggle the connections it works again for a minute or two. Any suggestions? Some type of cleaner? Buy a new car?
Re: OT Satellite radio Antennae connection Question
Barry,
I've never seen on, but...
If you can wiggle the connection and make it work it can be fixed. Try to note if the it is intermittent when the connector itself is moving or if it is when you bend or push/pull on the cable. E.g, hold the connector and wiggle the wire and hold the wire and wiggle the connector. If you can't tell, try the connector fix first.
If the connector itself is moving causing the problem, it may be dirty, corroded, worn, or bent. Fixing depends on the connector. Sometimes cleaning helps, sometimes bending/deforming the pins slightly works. If the connector is really bad try to find a replacement. Note that sometimes the jack is bad instead of the cable. After fixing it, I often apply a bit of dielectric grease to help prevent future problems.
If wiggling the wire makes any change, there is probably an internal break. If you can get a new connector, cut back the insulation and see how the wires connect then cut off the wire and solder to the new connector. If you cannot get a new connector, very carefully strip back the wire with an xacto or scalpel and cut off the plastic on the connector to expose where the wire is connected. Locate the break and repair. Sometimes the break is actually inside the wire where you can't see it, usually right at the end of the strain relief. Sometimes the break is at the solder tab. If the cable is shielded, it gets trickier. Once soldered, build a new strain relief. You can use epoxy or you might get away with tape, but better is SuGru, available from Amazon. It is a moldable rubber compound that goes on like silly putty and remains reasonably flexible when it sets up. I have fixed many cables like this, some of them quite delicate. (like an Apple Lightning connector)
If you can't do it yourself and have an electronics repair shop in your area, they should be able to fix it. Or find an electronics hobbyist.
Bill Howatt
I had a similar problem with a Sirius cable but at the receiver end. I was lucky, it turned out to be the shield which I think is also the power return for the electronics in the antenna. I believe they are active devices that have an amplifier. Anyway, I was able to do a bit of soldering very, very carefully.
Trouble with electronic stuff these days is that even if you can get it apart, the parts are difficult to see and if you can see them, even more difficult to fix because of their small size.
Bill
Was not clear......
I think the problem is on the receiver end. This little receiver (?) is about the size of a deck of cards. It has a magnetic antennae that sticks to the top of the roof and wire runs back to the unit. When the signal drops out I fiddle with the unit and wiggle the wire and it goes back to work for an unknown amount of time.
A few months ago I bought a new antennae and my dog chewed the wire within minutes or putting it in the car.
Just thinking of "greasing" the connection with something, just not sure what.
Re: Was not clear......
As I mentioned, dielectric grease is good for electrical things. Available in auto parts stores, big box stores, Amazon, etc.
I will find some today. This is very irritating. (I just want to listen to the radio. Not repair it, grease it, replace it, just listen to it.)
Why would the connection go bad by itself? Moisture, heat? Or does it get handled, bumped, moved? If so, once it is working reliably again I might consider reinforcement to prevent future movement.
