I was wondering if any of you might have some land survey experience to help me.
My nephew, cousin, and I have leased some wooded bottomland for hunting. I already had a paper quad which shows the section lines like described whenever the land was first surveyed. The problem is, that the East and North side of one of the 40 acres was clearcut about 4 years ago, so there are on trees left our there with paint.
I tried pacing off 440 yards along the South line, but it is a real obstacle course due to tops left from logging along with about 5 blow-downs and sloughs. I can find this quad online, but it isn't interactive. I've been trying to find a map with these Range / Township, section lines that I can either move my cursor over to get GPS coordinates like I get with Google Earth in my iPhone, which shows satellite images, but doesn't help me find my corners.
You should be able to scale lat and long off the map, or get it from an interactive map. Surely a GPS does lat and long?
When I worked for a surveyor in the summers, we were forever crawling around in the brush looking for benchmarks or section corner monuments. While I would have found a GPS to be a wonderful thing back then, I bet my boss would have said it was insufficiently accurate
The GPS can be fooled by tree canopy. I found it works better in the winter. I get good lat/lon coordinates from paper topo maps by drawing a grid and measuring between lines.
Read it twice and I remain unclear what you need to do that you can't.
If you need lat and long. from a topo just download the relevant topo and these values are displayed on the bottom wherever the cursor is positioned. If you also download Terrogo you can measure and do all sorts of stuff off the topo.
I have found this, but there is still a problem to work through.
while the Section lines are there, I still have to try to divide that into quarters, which I had already done on my paper map, but not so easy on here, but the worse part, is that rather than showing Degrees º minutes ' and seconds", the cursor placement reads degrees minutes, then decimal thousandths, which need to be converted, so out in the field, I can get back to seconds.
My nephew has the GPS, and I'm wondering if it has settings which can be changed to decimals, do any of you know about that?
Oh, you mentioned the phone not being very accurate in dense foliage, have you ever noticed how bad the compass can be when it is first turned on. I was back out in the swamps about a year ago without a compass when some clouds rolled in. I pulled out my phone, then into the compass app. I picked out a course and started walking. Due to it getting late, I kept pulling it out for a reading, then shutting the screen off to save battery. After walking about a half mile, I realized that I was right back where I first pulled it out, and the darn thing was off by 180º, until I stood there about a minute.
This depends on the phone - some are horrible, some are marginal, and some are good. On my phone, before I use the compass I use a program called "Phone Tester" to look at the actual numbers reported by the magnetic field sensor. If the numbers are too high (or not moving) I don't use the compass. Usually the field sensor can be calibrated by rotating the phone several times around one or more axes. I watch the sensor status - it should be on the order of +/- tens of uT, not 100s or 1000s. One of my phones had a design problem that so bad that the sensor was "stuck" and needed to be triggered by degaussing with a strong magnet or coil to "wake it up". Worthless. I personally carry a real pocket compass when in the woods or traveling (helps when turned around in Venice!)
As for the lat/lon units, you can convert in the field with a calculator - 60 sec per minute, 60 minutes per deg. For decimal seconds, i.e., DD MM.mmm to DD MM SS, multiply the fractional part of the minutes by 60. For example, 3.5 minutes would be 3 minutes plus .5x60, giving 3 minutes 30 sec.
For GPS on the Android phone I use an app called Ulysse Gizmo. It can be set to use whatever format desired (DD MM SS.sss, DD MM.mmm, or DD.ddd). It also has great compass, and clinometer support.
One more thing, the older GPS units that will accept an external antenna might pick up satellites better in the woods. When we bought this farm I carried one around and verified each corner on this convoluted plot that I couldn't find by looking. (22 pins!) However, The new GPS devices are probably more accurate. Note that none of consumer units are good enough for surveying. When I needed one property line pinpointed I got a surveyor with laser equipment to do it - fortunately we had iron pins to work from (located years ago with my GPS!)
A friend had to find survey stakes in the bush and he used a GPS. It was an older model but intended for hiking and not car use. He was able to locate the stakes within a few feet of where the GPS thought they were.
I use the Locus Maps app for android. It allows you to do all kinds of fancy things, such as download maps in advance so that you don't need a data connection on site. One especially useful thing you can do is overlay points, lines, or even images on top of a map.
When I want to know where my property boundaries are, I overlay a semitransparent version of the survey map over a satelite map. Then, by turning gps on, I can see exactly where I am at on the survey map, while in the field.
To set up the overlay, use something like google earth. draw your property lines or import your survey map. Rotate and scale it to match up to the base map, and then export it as a .kmz file. This can be then be imported into Locus.
I had already done this, but thanks for reinforcing it. <"As for the lat/lon units, you can convert in the field with a calculator - 60 sec per minute, 60 minutes per deg." >
It confirmed what I had calculated, and that one of the two corners I'm looking for is out under water in a slough, about 5' deep right now. Maybe by mid August I'll be able to walk out there if it dries out by then.
I'll pass this on to my nephew. He is the one that needs that tip. I already had all the lines locked in by memory, and know all the topo and trees well enough to find my way around out there without anything but a compass, and only that when it's dark or overcast. But when I took him out there to show him around, we'd come to a line, and he would always be confused about where he was on the map.
Afterwards, when we were back at the cabin, I ask if he had it's location marked in his GPS, and he smiled and said he did. I just hope he doesn't go out with weak batteries. ha
