OT tube filler
Gary Smyth
I have a thought to fill 1/2" EMT conduit permanently with some sort of inexpensive filler that will make the tube more rigid. I was thinking of epoxy, some sort of liquid rubber or expanding foam or something like it. Weight is not much of a consideration but something like lead is not in the plan. Expansion and splitting the thin walled tube if the filler expands is. The item's end use is as a "handle" that was bent into a wide "U" shape. I think that it will hold up in light use, but a filler of some sort would make me feel better as it is pulled/yanked over time. Filling the tube will also prevent kinking. Is there some sort liquid that can flow into the tube, and solidify to make the tube handle act more solid in use? Would play sand work? Whatever comes to mind will be considered.
