Metal working question.....
A friend of mine needs to drill a hole through a rack gear. Its a metal track that has teeth like a gear. The teeth are about an 1/8" apart at the bottom and a 1/4" at the top. Need To drill a counter bored hole. The actual hole is about an eighth and the counter bore is about 5/16". The problem is the drill bit for the counter bore grabs the shoulders on the teeth of the gear and runs all around or snaps the bit. Is there a metal working bit that has a counter bore built onto it so the smaller portion would act as a guide?
The idea is that the head of the screw needs to be recessed below the teeth of the pinion gear.
He's trying to do this on the job without the benefit of a drill press.
Any suggestions?
