made a miter sled
I have never had a good time of cutting miters. Faced with making a bunch for the spice box molding and a picture frame for granddaughters art work I dashed one together from the recommendations here at WC. It works grand.
The back bolt hole for each leg is drilled oversized, the front hole is snug. I cut two miters on the left side then test fit to see if it was 90 degrees. I empirically adjusted the leg to get perfect 90 degrees miter then locked it down. Repeated for right leg.
