bandsaw blade set
bandsaw blade set
bandsaw blade set
Jerry Gibbs
I have spent far too much time trying to get a 1/2" bandsaw blade to rip in a straight line. It always curves to my right as I push. I was able to get a 1/4" blade to consistently rip straight lines. My guess is that the set is off on the 1/2" blade. I will get a new blade, but I am curious how to correct the set. A teacher gently tapped the length of my dozuki blade to correct bad set, using a small hammer. Will it do any good to hold a stone against a running blade? Just curious.
Re: bandsaw blade set
Very doubtful. People have devised ways to sharpen a bs blade, but once the set in gone, it's time for a new blade. The band depends on precision in the tooth sharpness and symmetrical "set". Loose one and the blade will not track straight because the teeth are taking a deeper bit on the opposite side. You could pay to have the band sharpened and reset, but it would cost more than a new band by a factor of 2 or more.
Yonak
If you consider the blade unusable it couldn't hurt to experiment. Then we'd all know.
Put the blade in upside down and introduce a stone or hammer or something into the side of the blade it's tracking toward and see what happens.
test
Jerry Gibbs
I installed the blade up side down and applied a stone to both sides. The original problem was that the cut curved to the right. It now curves to the left, but less. I will get a new blade, but applying a stone might help in a pinch.
Re: test
William Duffield
I don't understand why you need to turn the blade upside down to stone it. You are removing material from a side of half the teeth, not the face of the teeth, so the direction shouldn't make any difference.
I assume you have already properly adjusted the blade to the wheels and properly adjusted the guides. Any of those parameters out of adjustment can cause the blade to track incorrectly. Those adjustments must be made correctly before you can determine if there is something wrong with the set that could be adjusted by stoning. If you haven't already done so, search YouTube for "Band Saw Clinic with Alex Snodgrass," watch it, and follow his advise.
If your guide rollers are set too tight or if you try to cut too tight a radius, you can squash some of the set out the teeth on one side of the blade. That might be corrected by stoning one side of the blade. It is very easy to overcorrect the drift by stoning the teeth. If you take out too much set, you won't be able to fix it. Any of the mistakes mentioned in this paragraph can overheat the blade, removing its temper, in which case the teeth won't hold their set, or their edge.
Before stoning the teeth, you should try using the stone to round over the back edges of the blade. This can take off a small burr that could cause the blade to drag to one side and will make it easier to turn a tighter radius.
