Scratch Stock for Inlay Stringing
Jack Prescott
I am looking for some input on how to best make a scratch stock for inlay stringing. I have tried several approaches with mixed results and am not happy with the results so far?? Thanks
Jack Prescott
Re: Scratch Stock for Inlay Stringing
Dick Coers
Are you having trouble with the steel, or with making the wood body?
paul in AZ
Having messed with this with great frustration and cost of time I'm not sure I'd ever want to make stringing from scratch again. There are sources for this from plain woods out to the complex patterns of guitar purfling.
I have wound up buying holly strings. Saves a lot of angst.
One example [no connection] is http://inlaybanding.com/stringing.html
Depending on where you are doing this I have cheated and made laminates instead of inlays. Bandsaw thin strips of 4/4 accent wood, glue these to the main lumber, plane it down to desired width and add another piece. This has worked nicely for accents on things like table legs if the 'inlay' is longitudinal but of course is dodgy for end grain such as going around a table top.
I don' t understand the question
Tell us what you are trying to do and where it is failing?
Jack Prescott
I have made the scratch stock blade from a hack saw blade and a utility knife blade (Stanley) by grinding and filing to the desired shape and then sharpening. I am not happy with the cut that I am getting. The "blade holder" and the stringing that I made from holly are good = just the blade is of concern.
William Duffield
Are you having problems with getting the width of the stringing correct, or are your problems with cutting the channel you are gluing the stringing into?
Jack Prescott
I am not satisfied with the channel that the scratch stock blade is cutting. I am looking for the best way to make a "blade" that will yield a good, clean channel. Thanks
It is all in the filing- Lee Valley to the rescue
Avoid the learning curve for filing and just buy a scratcher from Lee Valley.
However, if you are doing straight lines then a section of 14tpi band saw or hack saw blade does well, using the teeth to cut a trough. Or file some teeth in scraper stock.
Most use scraper stock for making scratchers.
William Duffield
I like the solution that Steve Latta developed and that is incorporated in the Lie-Nielsen cutters. First, I will note that it is not immediately obvious. The first couple of prototypes that Lie-Nielsen made, didn't work. For straight line cuts sharpen it like it was three teeth from a crosscut saw. The "saw plate" thickness needs to match the width of the stringing. For curved grooves, make it with two teeth instead of three. Three teeth make the blade too long to negotiate the curves without binding or blowing out the sides.
check out the L-N tools that these blades are mounted in, and then watch these two short videos.
https://www.youtube.com/watch?v=0APaNHfy9ek
https://www.youtube.com/watch?v=J29SIbEt-4M
The blade holders are the one down front and the one at about 10:00:
https://www.lie-nielsen.com/product/hand-tools/tools-for-inlay-deluxe-inlay-tool-set-?node=4066
Question
Having been presumptuous in my reply I need to ask what pattern are you trying to make in the cutter- teeth, or a vee cutter or something else. For these patterns most use scraper stock for the blank. It files well and holds up as well as anything that is soft enough to file.
