OT-Sandblaster Suggestion??
Tom
I am planning on re-painting a few bicycle frames and will need to sandblast them. I could take them to a local sandblaster but what fun would that be!
So I am in the market for a sandblaster. I have been looking at the Harbor Frieght models but thought I would check in here to see if anyone has had any experience or suggestion?
Thanks!
Re: OT-Sandblaster Suggestion??
Clint Searl
Clint Searl
An inexpensive syphon gun and an open reservoir that'll hold about 15 pounds of sifted play sand is all that's needed. Make sure the gun has a ceramic tip, and keep about 100 pounds of pressure from the compressor.
Re: OT-Sandblaster Suggestion?? *LINK*
Dustmaker Mike
I got this one to use in my sandblast cabinet and it works great. I have also used it in a 5 gallon bucket of play sand and it did just fine. Make sure the air going into the gun is dry I have three different water filters on my sandblast cabinet and two heading to the air chucks.
Sand Blaster
Agree and a WARNING
Hank Knight
I have the same one Mike has and it does the job. There are a bunch on the market and you can spend a fair amount of money on one, but it's not necessary. The inexpensive ones work well, especially for occasional use.
Here's the warning: WEAR FULL EYE PROTECTION. I used cheap plastic goggles that had ventilation holes on the sides. That was a mistake. The blasting medium bounces all over the place, in every direction, including sideways. I spent a miserable night and an hour at my eye doc's office the next day while he carefully picked little glass beads out of my eyes. Make sure your goggles seal all the way around.
I have the HF pressurized tank model. I used it to sandblast the rims on a van a few years ago, prior to having it painted. It did a good job using play sand from the Borg, but I did use quite a bit of sand.
I had a Crapsman 5 hp (rated peak, probably a 1 to 2 hp in reality) compressor with a 60 gal tank and had to wait to rebuild pressure after blasting for a minute or two. Have a little larger Campbell Hausfeld Compressor now (much better system). I did have to spread the sand on a tarp in the sun for a while to dry it. I also had some issues with water in the air even though I have a industrial double water filter on the air line and a separate filter regulator inline. I bought the HF blaster online on sale for less than $50 as I recall, and used less than $15 in sand. I did buy some of the ceramic tips with the blaster, used a couple to complete the job. Local sandblaster co wanted a large sum to do the job > $150 so I was happy.
Re: Agree and a WARNING
The HF pressurized tank system did come with a "Hood" with a plastic lens, the fabric covers your head, face and neck so I had no issues with sand in my eyes.
One more warning
Dustmaker Mike
Silica Sand is very bad for you. If you go the play sand route make sure you use a respirator rated for it.
I captured all the play sand in a plastic sheet made a funnel out of it and put it back into the bucket to spray again.
I have the HF pressured tank as well and it does a great job but for a one or two time use the siphon gun works just a well.
I am redoing a 68 Mustang it the reason I have a cabinet pressure tank and a siphon gun. At least that is what I told my wife(-;
Clint Searl
Suggestion
Clint Searl
Keep your goggles/eye shields from getting blasted by covering with Saran wrap.
Thomas E Norton
Mike, Does the ceramic tip last?
Take it to someone else
Dick Coers
Maybe not fun for you to think about sending it out, but;
Your air compressor is going to work up a sweat. Sandblasting is like cutting the end off the hose. You will get abrasive everywhere! Every nook and cranny gets sand in it, including your nooks and crannies! You'll be sweeping up sand for years if you don't work inside of some enclosure. It's going to be expensive to get an enclosure that you can fit the bike frame into. Then, it's tough to see the work since dust and abrasive are going everywhere inside the enclosure. Working with play sand is not healthy for your lungs either. It takes lengthy exposure, but silicosis is a serious lung disease.
Take them to a
Brian Roberts
commercial dip stripper.
You may be surprised at how inexpensive it can be.....and WAY less mess....for you!
Rick Christopherson
Not to state the obvious, but I assume you realize that you are looking for an open-air sandblaster and not a cabinet. They are fairly inexpensive because it is just a media tank and a gun.
The blasting media is so common and inexpensive that there is no reason to be using sandbox sand. It's so common that even some of the home centers here carry bags of the black media. I'm pretty sure both Menards and Lowes carry the bags for just a couple bucks, but Home Depot does not.
Sandbox sand is large, rounded, and has no cutting edges. So you needlessly have to run it at much higher pressure and with more waste to get the same job done. What's worse is that they cost about the same. So it is a waste to even try.
If you're going to try to recover spent media, just use a large tarp. Anything small enough to remain airborne beyond several feet isn't worth recapturing. Additionally, putting up near walls will actually cause more "overspray" so to speak, by bouncing the air off the walls.
Basil
Many years ago and over a period of time, I sandblasted several pieces of heavy equipment. Dry sand and a lot of air is needed and be ready to paint or prime when you finish. If left outside, things will rust overnight and almost as quickly inside.
I know that is no comparison to your bikes but one thing is for sure, the more air volume/pressure(125 psi+ continuiously) the better job you will get and the less sand you will use.
As others have already stated, I would say a hood, a respirator, heavy gloves and heavy clothes are a necessity even when using a small syphon model.
Clint Searl
Another use
Clint Searl
A soft-ish wood with prominent grain, like flat sawn cypress, responds interestingly to being blasted, by displaying a lot of decorative relief that can used in paneling, doors, and drawers, e.g.
Dustmaker Mike
Running sand they do not last a long time but they are pretty cheap and easy to replace.
Joseph Mulherin, sr
I suggest you buy the 50lb soda blaster from HF. For the small projects like the bicycles(how many?)
you will get a very clean job and not a lot of mess like sand will leave behind and in you also.
Rick L
Re: OT-How about phosphoric acid
Rick L
jasco prep and primer, even citric acid
http://lumberjocks.com/topics/105658
Look at the jointer...
Kneale Brownson
silicosis killed many a gold miner
Dustmaker Mike
If you use a soda blaster make sure to clean the prep the metal after you are done. If not the paint will not stick to it. Check out autobody101.com for a little more information on what and why. I choose sand because it is cheap (like me) and easy to come by. I use a plastic tarp on the ground under the car parts that are to big to go into my cabinet. it works for me
John McGaw
For something (relatively) fragile like a bicycle frame I'd suggest that you skip the sand and go for soda blasting which is more gentle but still removes paint and rust. Then I'd suggest that for such a small job that you take it to a pro unless you intend to make a habit of such work. Good equipment big enough for the job (compressor and cabinet) is not cheap and bad equipment is seldom worth having.
Re: Surface energy is short lived
TomD
so the bonding effect that sand blasting creates lasts about an hour at peak strength. As a result getting someone else to blast for you is not going to get you a better paint adhesion, other than some mechanical surface prep, and of course it gets rid of the paint. Unless you able to get to the painting stage immediately, and no contamination occurs on the way.
The reason materials rusts so quickly after sand blasting is the high surface energy in a moist environment will promote rusting, or whatever other form of ambient bonding is there like hydrocarbons.
