(semi- OT) Sherwin Williams paint match tool
Grant in Iowa
As a facility manager for a several building campus, a constant time waster is trying to figure out what color a given surface is painted so it can be properly touched up. Today, I was at Sherwin Williams getting a gallon of what turned out to be the "wrong" paint for a touch up. While waiting for it to be mixed, I was playing with a new scanner tool they offer called "Color Savvy Mobile Match" that will scan a paint color on a surface and tell you what color it is (in Sherwin Williams color codes of course). I became enamored with it, and it followed me home (OK, well, back to work).
I told the sales guy that I'd try it on several of the beige colors we have that are almost --but not quite-- the same. I said I'd see how good it worked and keep it if it was acceptable. Otherwise I'd return it. It works quite well, actually, correctly naming five in a row (I have records of some of them on file). In some places where there is high texture, such as concrete block walls, it wasn't quite right, but its third "guess" was the right color. Close enough for me, since I can compare the results to my list of paints used in the building and determine what I need to know. This thing will save me lots of time in walking around the campus, trying colors, holding up swatches, and buying the wrong paint color.
The device, when displaying the results, gives the user a "match level" meter that tells you how confident it is about the color it chose being accurate. It also gives a second and third possibility. This helps when you have several cans of paint that it "could be"
Another neat thing about it is that it can scan other objects and give you a SW paint code that will match. As I write this, I see that the company makes a generic version that includes 30,000 colors. The company also makes other similar products to help with paint color projects in other ways.
https://www.color-helper.com/MobileMatch.php
No affiliation, just a happy customer.
Regards,
Grant in Iowa
Re: (semi- OT) Sherwin Williams paint match tool
Jason Roehl in Lafayette, IN
Interesting.
I've had the S-W mobile app for quite a while, but its color-matching feature was garbage. I would try the app on S-W's own master color palette, and the "match" it would suggest wasn't close, which meant it was less than useful to me. I'm no app developer, but I would think that an easy fix would be to add a calibration feature, where it tells you to scan specific colors from the master palette (like a certain red, green and blue or something) near the surface whose color you're trying to match. That way there could be a computational adjustment for the lighting conditions. No need for a (yet another) separate device.
Jason
I agree, and...
Grant in Iowa
Jason,
I agree, and having calibrated a number of computer monitors over the years to display colors correctly, I can see that any such device must be calibrated to be any good.
I too had tried the app, but found it to be less than accurate. I am all but sure it simply needs calibrated.
Regards,
Grant
