Outdoor Plastic
Outdoor Plastic
Outdoor Plastic
don stephan
A recently built wheelchair ramp is exactly what my friend wanted, with one issue. The surface is 3/4" two sided MDO plywood supported by a treated 2x frame, resting on a brick step and sidewalk.
It was felt that tapering the plywood down to 1/16" or so of thickness at its lower end would have led to premature breaking off, so there is a 1" "step up" or lip. This poses no problem for wheelchairs but the homeowner is concerned that elderly persons may trip on this lip. A wedge 45" long (the width of the ramp) that tapers from 1" to about 1/4" over 6" of width has been requested.
A trial wedge of oak showed that wood is going to warp when the lower side is on damp bricks and the upper side is in the sun. Aluminum is not desired due to the risk of scratching/marking the brick. Plastic would seem to be a good material, so I'm asking for suggested compositions from those with plastic experience. Nylon? Acrylic? Polycarbonate? Other? The wedge would be shaped using a custom supporting base and router sled.
Thanks in advance.
Re: Outdoor Plastic
Re: Outdoor Plastic
Why not a piece of Trex or other similar alternative deck materials? Most of it comes with a wood grain surface on the top side and in various colors. It is pretty slick, but with only a 6' wide strip it should mot be a problem. Its made of recycled plastic and wood pulp, I think. If you only need a 45" piece, I would ask at the Borg if they had any that was damaged and they might sell it at a discount.
You might also use Azek which appears to be wood fiber compressed to a fairly high density. Make good trim, but not sure how it would do lying on the brick. Either of these aught to work well with wood working tools.
Another approach would be to put a none skid yellow and black stripe there to alert the folks to the little step. (Available at the Borgs as stair liners.)
Re: Outdoor Plastic
Re: Outdoor Plastic
John McGaw
At first I was inclined to say that UHMW plastic would be ideal but, on second consideration, I realized that something super-slippery was not wanted here. Barry's idea of Trex or equivalent seems quite possible. If it was tapered properly the upper textured portion would be uppermost and reduce any slippage concerns. Having it in a different color would provide a visual clue about the level change.
Re: Outdoor Plastic
Another use for Corian?
Re: Outdoor Plastic
Re: Outdoor Plastic
fabricate from an outside deck material. It will be sufficiently stabilized for this application.
