No sure what they are called but it is basically a "dish" that you can set the sand on and it will spin while the sander winds down. Saves waiting for it to stop and then put it down.
Since I am making a new rolling vac stand for my sander I would like to see about this item.
I have the Sander Sitter noted above. The crepe rubber in it is supposed to clean the sand paper while it spends down. I'm not sure that part does much. I seldom use it. I guess I don't have confidence I can just throw the sander in it and turn loose of it. I generally lay it on its side.
I will give that a try, but I think the sander will run around like a cat chasing its tail. The sanding sitter has what passes for a bearing and lets the tray spin.
For small tasks where there isn't enough weight to keep the part being sanded from dancing around the bench top, I use a piece of carpet padding. Usually I just sit the sander down on the foam padding while it comes to a stop. Works good enough.
