OT- Computer Question
Tom
Recently my laptop has been dropping or disconnecting from the Internet. I will be using my computer and then I am no longer connected. This is a recent phenomenon.
Thoughts?
Re: OT- Computer Question
Dustmaker Mike
Are you going wireless? If so reboot the router and the cable or DSL modem and see if that helps you out.
David Yoho
Sometimes rebooting your modem and wireless router (power off, wait a few minutes, and power back up) will take care of the problem. If it continues to disconnect frequently (wireless connection), the culprit most likely is a failing router. I went through this same thing within the past month or so. It was so bad I finally couldn't get an Internet connection at all. I traced the problem down to and replaced my wireless router and the problem went away.
This scenario assumes you have a separate modem and wireless router. If you have only the all-in-one unit often provided by the Internet Service Provider, then you might want to have them check it out.
mdclor
I had that issue, as did many of my neighbors, using a DSL provider and it was ultimately a hardware issue with the ISP. It only took a couple years to get them to seriously look at the issue and determine the root cause. I am now with a cable provider and so far no problems.
Tom
Thanks for your help!!
Bill Howatt
It can also be the wireless adapter at the computer. I had an add-0n Wireless-N adapter that started dropping the connection. Replaced it an all is well.
Bill
True, but...
David Yoho
That could certainly be the case for a desktop but a laptop usually has it built in.
Re: True, but...
Bill Howatt
I was using it on a laptop so I could get Wireless-N speeds.
The wireless adapter circuitry on the motherboard could fail.
Bill
Re: True, but...
Walt
Not always but oftentimes laptops will have a small WiFi card that plugs into a socket on the motherboard. It's usually easier to replace with a USB though not as neat.
