bolting a sculpture to a base
eliot feldman
I want to bolt a sculpture to a wooden plank. The sculpture is about two feet high and the plank is about two inches thick. The sculpture already has two holes drilled into it about three inches deep by 1/4 in diameter for two bolts. You have to assume that the holes are not perfectly parallel in space ( for the mathematicians out there, the direction cosines are not the same.) The question is how to drill the holes in the plank so that two bolts will go into the sculpture nicely. The idea is to epoxy them into the holes. I believe the problem is similar to what certain chair makers face when lining up spindles, which I understand is more or less done by eye. But spindles can flex a little, but bolts don't. I know I can drill the holes over size in diameter so there is room for inevitable error, but I am hoping for something more or less foolproof. Any ideas?
