How to cut Corian
How to cut Corian
How to cut Corian
I have a bunch of scrap Corian that I accumulated for eventual table saw inserts. Can I cut it with a band saw without trashing the blade?
Re: How to cut Corian
Walt
Do you have a blade that works but is nearing the end of its useful life? I've cut a little bit of Corian with no obvious harm to the blade. I don't know what effect cutting several feet would have, for example. I think most non-quartz solid surface material is a mix of polyester or acrylic (25%-35%) and the rest a bauxite-like aluminum compound, Aluminum TriHydrate. I don't know how hard or abrasive Aluminum TriHydrate is. Quartz solid surface seems another matter if this article is correct.
http://homerenovations.about.com/od/kitchens/a/artsolidsurfcou.htm
Tom
I have worked with Corian in the past and here is my suggestion. Make up a plywood pattern and then pattern rout with a good carbide bit.
I agree with Tom, but
Keith Newton
You can rip on the TS to get your straight sides, And then on the round ends, use the coarsest blade in your jigsaw set, running at a slow speed, cutting 1/8" outside the line would be easy enough. You want to feed fast enough to produce chips, whereas too slowly causes melting, with any blade on any saw.
john Veerkamp
Corian can be worked with regular wood working tools. It won't harm the edges. Probably softer than Osage Orange, Pecan(crete) or Elm.
Bill Turpin in WNC mountains
I have turned multiple pens from Corian. Cuts with normal chisels.
This was my very limited experience. Cuts with ordinary tools. Did not notice any degradation of the tools. I might not use my "bestis" bandsaw blade, but in truth for the amount you are going to cut I would use whatever blade was on the saw. I keep a 1/2" 3 tpi hook tooth blade on the saw for general stuff. Rip the Corian to strips the right width on the TS. I would rough cut the ends on the BS and then pattern route them with a cheap carbide router bit.
I had forgotten about the fact that the 10" blade will not fully retract on most saws enough to clear the bottom of the insert. You know enough to know it would be dangerous to try to under cut them with a ten inch blade. Use an 8" blade the same thickness as your 10" and under cut it. Hold the insert in place with a push stick or piece of wood while you raise the blade. I have a friend that cut several fingers badly by raising the blade into them. He's a lot more alert now and you are too. One way to do it is to park the fence on top of the insert, but not over the blade.
"Hold the insert in place with a push stick"
A 25# bag of lead shot works dandy.
I clamp a board (usually a piece of plywood) on the saw table as recommended by the instructions that came with a commercial insert.
BTW, these inserts come with material removed so a 10" blade will fit underneath. Could perhaps route such a clearance on a shop-made insert and skip the 8" blade mounting.
Janice Manuel
I've cut lots of it...carbide is best, it's tough on bandsaw blades. I always kept a fine tooth metal blade in my old 12" bandsaw for when I needed to cut curved lines. It is abrasive, and will dull any blade fast..It can be jointed also, if you take a really fine cut...
Jim Hoeller
I used my table saw to cut the parts I needed for window sills. I picked up a bunch of sink cutouts from a local "top shop". The colors were mixed so I needed to plan their usage to make sure the sills were a uniform color in each room. I used two part epoxy to join the individual parts, clamped then and last, sanding down to a level, smooth surface. After all that was done, I sent the blade I used to Quinn Saw for sharpening.
I was McGivering. I don't have a 25 Lb. bag of shot, but I bet I would find a lot of uses for one if I did. I do have abut six five pound blocks of plumbers lead and they are surprisingly handy. Hmm, next time I make inserts they will get some use. I like John's idea of routing a slot, but doing it on the actual saw assures you the position is correct and it's pretty fast after switching the blades.
I know I don't have to tell you, but keep your hands out of the saw. I met a fellow, a friend of a friend, who cut off about half of all four fingers on his right hand. It gives me the willies just typing this. We should have a picture of his hand in some sort of shop safety section. His wife raced him to the hospital. They forgot to take the fingers. And to make matters worse, he used to be a dentist. Now he's a car salesman. On a good day.
