Finish for Winsor chairs
Dave in Bryn Mawr
Client brought a reproduction Winson rocking chair with a beat-up finish. He said he would like a natural stained finish. I told him that all Winsors were pained because the chair parts werre made of different woods. I want to change his mind. Am I right? Any other factors?
Thanks!
Re: Finish for Winsor chairs
consult the oracle
Find Curtis Buchannan web site. Find his tutorial on chair finishing. Show client what one of the best current makers does to replicate this chair. (milk paint and a top coat)
Ralph Lipeles
If I recall Dunbar's book correctly most were painted. Natural finish was only used when the customer had strong feelings for it, rather then for tradition.
I took Curtiss's class many years ago and of course we painted the chairs. I've been studying Windsors ever since and I do see a fair amount of them unpainted built by local artisans. Most of the time (I can't say 100%) the unpainted chairs are made from the same wood throughout. I have the book Windsor style in America but 99% of the pictures are black and white and in the index there isn't anything mentioned about paint of finishes. It might say something in the beginning but I would have to re read it.
You could always strip the chair and see what it looks like and then have the discussion with the client over finish.
I've made a few Windsor chairs and settees.
Most I have finished natural - a few I have painted.
For me, it depends on the seat wood.
If the seat wood is pine or poplar, I usually paint it. If the seat wood is cypress, oak, cherry, butternut or a wood with an attractive grain pattern, I will stain it.
I have stained parts of a chair and painted the rest.
The big problem is unifying the color. I usually use Transtint or a similar dye as most stains have really different absorption properties on the dissimilar woods.
William Duffield
So as not to repeat my recent faux pas regarding trimmers, I need a clarification: Do you mean a Windsor chair? If so, I can suggest two more authoritative references, one of them with deep and thorough arguments on why they were traditionally painted, and why it is still the best strategy. If you really mean Winsor or Winson, I can't help.
Mike Jurnigan
I have built a few Windsor’s over the years, taught a few classes, and have done countless demos around the country. Most old/ antique Windsor’s were painted, a few were made from a single wood, such as walnut, had a clear finish. Most Windsor’s were painted with an oil based paint that was white lead based. White lead base paint cannot be used today, except in a historical context, such as Mt. Vernon. Per Drew Langsner, the earliest mention of milk paint used on Windsor’s was around 1850. You will find a large number of old chairs with their paint stripped off and a clear finish applied. I have two this way myself. Talking with several people that work with museums this was probably done around 1876 (the first centennial). This is when America first gained an interest in antiques. So, if the clear finish is old, it has been accepted as being OK.
From my perspective, if the chair was made after 1900 and it has a clear finish it would be appropriate to refinish it with a clear coat. If it was painted, then I feel it should be repainted. The question should be asked, does the customer want it to look new or old and do they want a historically accurate finish? If they want it to look new and have a historically accurate finish that will be hard to do, because you cannot legally apply the historically correct paint. However if they want a paint that looks like the paint of old, Drew Langsner taught me the recipe that he uses in his book the Chairmaker’s Workshop. He recommends mixing 3 parts of high quality Satin alkyd enamel interior oil based paint (he personally recommends Pratt and Lambert) to 1 part flat or satin polyurethane varnish (I recommend the flat or dull rub poly). He then applies 2 coats of primer followed by 3 coats of paint rubbed out between each coat and a minimum of 24 hours drying time between coats. This will leave a nice low luster finish that is tough as nails and more flexible than the paint alone. It wears well and where it wears through, the wood that shows through will have a nice and polished patina. If the customer wants something that looks old, but is not historically accurate then apply milk paint.
There is nothing wrong in trying to educate the customer, however refer to rule number 1 in business; the customer is always right. Rule number 2, when the customer is wrong, refer to rule #1. The customer is paying for what they want unless it absolutely goes against your moral fiber, give them what they want, unless you know it is a valuable piece and that they would ruin it by doing what they want. At that point, I would refuse the job and let them take it elsewhere.
more from Curtis
Curtis told me that it was common in the late 1800's to strip the paint from old Windsors and varnish them. In fact I have one, originally finished an ugly green in late 1700's. It looks fine, but I would rather it be painted an attractive color.
