Spice Box- Installing the tops
I'm nailing them on. Glue across front and two nails down each side. I have become less and less inclined to eschew nails as I look at more and more antiques. I think avoiding nails is a modern phenomena.
What's this! Cut nails from Lee Valley are soft steel, annoyingly soft steel. They can bend all too easily, even after driven in 90% of the length. So, by painful experience I know that I need to test the pilot holes for cut nails. Indeed, this is the test piece of walnut being drilled with various sized pilot holes and test nailed. It took three drill sizes to get an optimum tapered hole that would accept the long nails without bending. Thankfully I have a set of number drills and a caliper to measure nail diameter.
Mr. Lee, are you listening? Provide cut nails that have some temper.
Re: Spice Box- Installing the tops
Rob Lee
Hi Bill -
Sorry you're having problems with the nails - we buy from Tremont Nail, an American firm in business for more than 190 years. I am unaware of another supplier of this type of product.
Rob
Keith Newton
Bill, They are not square, but paneling nails, the colored ones with rings are hardened.
Also, you probably already know that having the right size hammer is very important. You need very quick taps from a lighter hammer on lighter gauge nails. A large hammer delivers too dull a thud which will lead to more bending.
Another thing which helps, is to rough up the hammer face. Every so often, I like to lay a sheet of coarse abrasive paper on the bench, then press down hard with both hands, while slowly abrading a cross hatch in the face. This keeps the nail head from slipping out from under the head on a less than perfectly square lick.
