yellow tint on lacquer from spray gun
chris
I am using spray gun to spray a waterborne lacquer in glosd on some painted pieces. Although many of the pieces came out perfect, a few the colored has dulled and there is a yellow tint to the piece. Why would this happen? Did I spray too much lacquer? How can I fix it. This is a very, very special project and I am devastated. Pleasr help. Thank you so much.
Re: yellow tint on lacquer from spray gun
Best contact the maker of your lacquer. WB lacquer should be water-white unless it's been intentionally tinted.
Dick Coers
What brand lacquer? What paint? Hot and humid in your shop? Some manufacturers put amber dye in the clear to counteract the blue cool look on darker woods. Maybe too heavy of ooat on a color that is barely compatible. WB is very sensitive to atmospheric conditions. Getting close to the difficult season where I live. All just guessing with the limited information.
Not enough information
If you want an answer you need to do some testing. (It always better to do chemistry experiments on a test piece than on the finished project, as you discovered)
Is the top coat inherently yellow? Coat on glass, let dry and see.
Is there rust in the spray gun?
If the top coat isn't inherently yellow then either it leached something from the paint into the clear top coat that was yellow or leached something that made yellow through some chemical reaction.
Does the yellow depend on the paint color over coated? Coat test panels coated with the various colors and observe result.
report back
It is impossible to suggest a fix without knowing the cause. What kind of paint? I have top coated milk paint with out any problem.
