Dosch Trimmer
Dosch Trimmer
Dosch Trimmer
Vince Molnar
I have a Dosch Trimmer but I'm missing the handle. Any advise on how I can obtain a replacement handle?
Re: Dosch Trimmer
Do you mean Bosch?
Re: Dosch Trimmer
http://www.ereplacementparts.com/
Re: Dosch Trimmer
Re: Dosch Trimmer
William Duffield
I agree with Del. That's the first place I would look. But, to successfully find the part you need, before you go there, you must know how to spell the brand name, and you must know the model number. Sometimes, the manufacturer has "improved" the tool over the years, in which case you may also need the type number, or even the serial number. These are usually clearly marked on the tool itself. You will probably also need to be able to interpret exploded parts diagrams, some of which are not very high resolution. If you can't read them, you can often find higher resolution diagrams on the manufacturer's website.
Re: Dosch Trimmer
Re: Dosch Trimmer *LINK*
I'd never heard of Dosch until you asked, Vince. Similar to a Lion miter trimmer, it appears. Ereplacement Parts is unlikely to have a part for this grunt-powered tool, and the company's out of business.
You might wander over to old woodworking machinery (link below), register, then post a "want to buy" in the BOYD forum. Failing that, post a request in SWARF seeking a description of the handle, and figure out how to make your own.
You might find some helpful information at http://www.vintagemachinery.org/mfgindex/detail.aspx?id=260
http://www.owwm.org/
Re: Dosch Trimmer
Re: Dosch Trimmer
Brian Roberts
Could be a difficult handle to make.....but not impossible.....
See here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=260&tab=4
Re: Dosch Trimmer
Re: Dosch Trimmer
Barry W. Larson
Hi Vince:
Try Grizzly. They have a pretty close knock-off of the Dosch/Lion mitre trimmer and the handle from that unit will likely fit. I obtained parts for my Lion mitre trimmer from Lee Valley who carry a similar product but they had to special order them for me. The link for the Grizzly trimmer is as follows:
http://www.grizzly.com/products/Miter-Trimmer/G1690
Cheers,
Barry W. Larson
Calgary, Alberta, eh!
Re: Dosch Trimmer
Re: Dosch Trimmer
Rum
Check the sides of the dovetail on the cam to make sure they're still good before you invest to much in an authentic handle replacement. If they are still good make sure you don't reef on it to much when you get it working because it seems that that is a weak spot.
Both my Dosch and my Lion have one side blown out. The Dosch someone brazed a new handle on before I got it. The Lion was busted when I got it (I knew that, the price was ok) and has the handle sitting on the side; I haven't figured out what I want to do with it yet. Ideas so far are to rebuild the dovetail with brazing and file work, braze the handle on permanently like the Dosch or drill and tap the cam to attach the handle.
If it was me and the dovetail was good I'd take a bar of square (well rectangle) stock and make a new handle from that. It wouldn't take to long to cut the dovetail with a hacksaw and file and you could with cut down the handle or drill and tap the end to put on a nice wooden handle. It wouldn't be period perfect but it'd be functional and if done right could look pretty good imho.
The Dosch has much nicer setup for setting the angles and the like from what little I've played with it, congrats on the find :D
Re: Dosch Trimmer
Re: Dosch Trimmer - grizzly handle
Rum
You're right, the grizzly handle looks identical. I can't tell the actual dimensions but it wouldn't be surprising if it was dimensionally identical.
I'm guessing this is the part: http://www.grizzly.com/parts/P1690028 for $11 it'd be worth a shot.
I wish they had a full diagram, I'm thinking I might be able to replace the gear on mine (the part I think it might be? it is is only $4).
Re: Dosch Trimmer
Re: Dosch Trimmer
Bob Entwisle in NJ
Vince,
you might try contacting someone at CRAFTS of NJ.
http://www.craftsofnj.org/index.php
I think the Dosch was made in Union NJ, and someone in CRAFTS may know something about it and parts for it etc.
Bob in NJ
Re: Dosch Trimmer
Make one
If all you want to do is get the trimmer into user shape, it would be really simple to make a handle. There's a fair amount of force on that little dovetail where the handle inserts into the sprocket, so if you want to make a wooden handle, it had better be something really strong like hickory or ipe. You could also have a machine shop mill you a steel one for not much money.
If you're trying to restore the trimmer to original condition, OWWM might be the best place to start.
Ellis Walentine, Host
