Computer Question/software/Word? OT
My computer is running windows & Home Edition and a Microsoft suite that includes Word. Word has decided it will not print. I get a little circle that just sits there spinning and a note on the bottom of the screen saying something like "widows is preparing to print in the background", but it never prints. If I give up and shut it down, a screen comes up and says it searching for a solution, but never finds one. When I restart Word, it has saved the document and I restart it and save it again.
What to do? Reload Word? Go online and get a print driver?
Re: Computer Question/software/Word? OT
John McGaw
First off, have you determined if other programs will print successfully? If they do, the problem is clearly in the non-printing program. If they don't then it is going to be a systemic problem.
I'd suggest that you go into computer management and look at the event logs to see what kind of errors are showing. Right-click on 'computer' on your desktop, select 'manage', select 'event viewer' and browse through the windows and application logs.
The other things are printing successfully. In order to print out a letter yesterday I typed it in Word, saved it, e-mailed it to myself as an attachment and then printed the attachment.
John McGaw
I am not a Word user but there is probably buried somewhere in the program a printer selection and setup section. It would be worthwhile to check what the program thinks it is printing to and how since it is not unheard-of for a program to randomly decide to print to a non-existent device (or to a virtual printer on disk).
ebd
ebd
Switch to LibreOffice. It's free and has everything that MS Office has and more. It can read and write MS formats and for me on both Win-XP through Win-8.1 and PCLinuxOS it has worked flawlessly.
I have over reached my very limited (non existent) computer skills.
I went into Word and checked the printer setup. Somewhere along the way I unplugged the printer. I plugged the USB cord back in and it installed a second version of the print driver. I made that the default driver and it went back to work. But, I still can't convert to adobe pdf files. I have an older version (6?) of acrobat installed and it used to convert documents into PDF files. This compressed pictures enough for me to send them into the VA. I am guessing I need to reinstall the adobe to make it mesh with the new print driver. ???
Its hard to imagine how much I hate this stuff.
BrianMonumentCO
To err is human!
To really screw something up requires a computer. Specifically a microsloth windows system.
Re: Converting Files to PDF format
Doug Wolf
Barry, I've been watching you struggle with converting files to PDF for a long time. There are several free programs that perform this function. I've been using "doPDF7" for several years and convert all of my monthly statements, e-mails I want to save, order invoices, etc. with no problems. I highly recommend looking at it to replace your non-functioning Adobe program. The download link is below. Just read the screens carefully when you install it so you don't download any surprises or unwanted programs. There is a new version 8 but I use version 7 so I can recommend that one. It installs as a printer driver and you just select it as your printer and print to PDF, couldn't be simpler.
http://www.dopdf.com/download/setup/dopdf_7_3_400.exe
Jesse Cloud
This kind of stuff is what drove me to Apple. Much less fussing than with a PC and Windows.
I use Word on Apple, and it is the least well behaved program on the system, but it still works better than it did on Windows. Converting to PDF is just an option in the Save As dialog box.
I worked for many years troubleshooting computers for a living, it was kind of fun then. But now I'm retired and actually have a life, so I have no patience for that kind of stuff.
C. John Hebert
use alt and the letter p at the same time
John, I do that regularly, but now it just sits and the little circle spins. I have downloaded a second version of the print driver and it seems to work. Still no connection to Acrobat though.
Walt
I don't install ANYTHING from Adobe (or Microsoft) unless there is absolutely no other option. For printing .pdf I use cutePDF. It's free and I've had very good luck with it. There are others similar. LibreOffice has export to pdf as one of the buttons, no additional software required.
