About time I did this, not getting any younger
Keith Newton
I'm on the front end of building a big house full of cabinets. The designer wants to paint all of them, and has specified Extira for everything. This is a waterproof grade of MDF, which weighs just under 100 # per 3/4" sheet. While I can still handle it by myself, it is just so hard on my joints, that at 67 years of age, I'm not to excited about it, and facing the possibility of eventually aging out of being able to at some point.
So I've been thinking about devising a way to get full sheets from my box-trailer, through the shop door, then onto the table-saw without having to lift the full sheet.
What I've done, is buy a Stanley sliding barn door kit. The box comes with two sets of rollers, and I've bought 30' of track, which I've screwed straight onto the ceiling, starting centered over the door, then running out to about 4' in front of my Unisaw.
I picked up the smallest Electric Hoist that HF offered, for about $125, and hung it off one of the roller sets. Then off the bottom of the hoist, I took the vacuum blower off a little 1 hp Sears 1 gallon vacuum, discarding the canister, and cutting a hole to fit it into an old drawer box which was cut wrong, about 16" x 20", or 320 square inches of area. I also bored 2 holes through the 1/2" thick bottom, for a U-bolt to lift by. I sprayed the top edge of the drawer box with contact cement then applied a strip of foam to help the vacuum make a good seal against the face of the sheet-goods.
Some time over the last few years, I have mentioned using a shop vac for holding templates to work, and mentioned that all of the shop vacuums that I had tested would provide about -1psi. However, I tested this little thing pulling against a block of wood hanging on a fish scale, and was surprised that the 4" area pulled 6#, or 1.5 # psi. So my little drawer box should be pulling down @ 480 # or capable of lifting that much, which is more than my hoist will lift, or more than any material I'll be lifting.
Now comes the hard part,,,,,,,,,,,, Teaching the "Old Dog new tricks" ha. While tweaking one thing or another, Ive gotten a sheet up there a few times, ready to feed, but didn't have the saw turned on, or without clearing the out feed table of the last sheet. I've still got a few things to work out, like stretching a wire alongside the track to tether the power cord onto rings spaced about 5' apart, to keep them tidy and out of the way.
I'm even thinking about buying another section of track to put perpendicular to this one, just off to the left of the TS, to carry the outboard end, if I want to do cross-cuts first. This might turn my Unisaw into a poor-man's sliding-table saw.
I'll try to post some pics when I get all the bugs worked out.
Re: About time I did this, not getting any younger
Re: About time I did this, not getting any younger *LINK*
Dick Coers
The panel handler cart is a really nice way to handle heavy sheets as well. With it's hydraulic jack, you can keep lifting the bundle as you slide the sheets over the saw. Looking forward to your pictures!
panelhandler
mdclor
I'm probably just missing something, but why not just use a track saw and break the panels down while still on the truck or slid out onto a couple saw horses?
or go high tech
BobS
Why not just send a parts list to your local CNC shop and just do the assembly in your shop? Been doing this for years and can see no reason to go back, the cost is less than you would expect and no heavy lifting required. Get your parts line bored, hinge hole bored, etc. with no shop time, instead use the shop time to work on another project.
Re: I have an advantage!
Having raised 6 children, 5 of which were boys, and having a slew of grandchildren in their late 20's, I have my youngest son living fairly close. He is quite strong and I can call on him any time he isn't working. So when I have large sheets to break down on my Unisaw, he is here, if the material is very heavy, he will bring one of his stepsons!
No mechanical issues, no weight limits, no problems!!
second track saw
Jerry Gibbs
You don't have to break down with a track saw. You can make the final cut, weather permitting, outside.
Re: second track saw
William Duffield
But, if it's a Festool tracksaw, you don't need to make a second cut. The first cut is the final cut.
Jesse Cloud
And you can stack up a few pieces of sheet goods, align and clamp, then cut them with one run of the track saw. Saves a lot of time. And there's next to no clean up needed.
