Painting shop drywall
mdclor
I recently moved to a house with an unfinished basement. The walls are mostly studded, but more needs to be done, then the electricity and drywall. I am pretty will set with everything (although nothing is done yet) except the painting. I have an AccuSpray gun 12S (IIRC) and a 60 gal IR compressor. I will paint (when I get to that stage) with latex. Does anyone know the recommended needle/nozzle for this? Should I plan to thin the paint? Should I use a primer, then the actual paint or just two coats of the paint? I intend to use a very light tan to best match the dust color and maximize light reflection. I would like to use a semi-gloss because dust doesn't stick to it like it does to flat paint and will be much easier to clean when the time comes. Any recommendations as to preferred brands of paint? Any other considerations? TIA!
Re: Painting shop drywall
Jason Roehl in Lafayette, IN
Skip the sprayer unless you use an airless. It would be an exercise in tedium, as HVLP or conventional spray are much too slow for the volume of paint you need to apply (300-400 s.f. per gallon is typical for interior paints). Not to mention, conventional spray will put a LOT of tiny overspray droplets in the air.
Sprayed primer on new drywall still needs to be back-rolled while wet. Whether you spray or not, use a primer specifically labeled for new drywall, not a general primer-sealer. Once the primer dries overnight, take a pole sander to it to knock off any nibs and places where the drywall sanding roughed up the paper. Then use two coats of a decent interior acrylic wall paint. I wouldn't recommend semi-gloss, but go with either a satin or eggshell sheen. They will still be slick enough to wipe and keep dust from sticking as much, but won't have near the glare that semi-gloss will. Stick to light colors to help with light diffusion.
Jason, 19 years painting and counting (but not much longer...)
kenscabs
I'm with Jason, skip the sprayer. Rolling goes fine unless you're doing thousands of square feet in new construction. It'll take you longer to clean the equipment then the actual painting. I just did a fair amount of drywall work in my office and I've always hated the "drywall primers". I used Zinsser Bulls Eye 2 Multi-Purpose primer and sealer and am very happy with it's coverage.
TomD
Primer is a must in my experience, otherwise the topcoats just disappear, plus you get uneven look over the compound.
When I did my shop, which is at grade, I remember there was a TOH episode where they were building a mansion on spec, and it included a workshop. I rather pride myself on my drywall work, and have been hired by pros to do it (though my methods make more sense in the home). So I wanted a real interior space and drywalled. The TOH gang did theirs with aspenite and sprayed it with latex. Over the years I am not sure I made the right decision. I don't know if I could have used aspenite, particularly if it had a strong glue smell. But the problems with drywall are that it is cold, it is almost as though it doesn't mater that the room was insulated, the rock picks up cold from the floor, and thermal breaks and acts like a radiator in reverse. It damages easily, though repairs are easy, and the aspenite wouldn't look that great undamaged. And there are many structural advantages to aspenite, or panels, as far a hanging gear, or designing and accessing chases.
If I went with drywall again, I would do a skim coat plaster job instead. That stuff is not easy to come by here, and so I couldn't use it when I did my shop, but it looks better and is often as fast to do in a domestic situation because one often has so many joints that the best way to hide them is skim coat anyway. And it allows more finish options, is flatter, and a lot tougher.
Jason is the expert here so i certainly won't argue with him! When I built my 30 X 30" shop about 10 years or so ago, we dry-walled the shop and finished it. I believe I used Kiltz primer then we roll painted the walls with the best Valspar interior satin finish latex in Woodsmoke color (it is a light blue gray). It worried me some as it dried as it appeared there was going to be "streaks" of darker lighter areas, but when it finally dried a day or so later it completely covered perfectly.
I painted the ceiling with the same primer then Valspar best ceiling paint. The only issue is that the ceiling does seem to hold some dust (not going to clean as I have 10' ceilings. I do have a few "nicks" in the drywall, but nothing I have deemed sufficient to patch and paint. I have cabinets on about 3/4 of the perimeter hung with French cleats.
I built the shop with 2 X 6 walls on 16" centers so have no issues hanging anything I wish on the walls. The shop is heavily insulated and is heated and cooled with a furnace / central air system installed in the upstairs room, and is quite comfortable in both summer and winter.
After 10 years I am very happy we built the shop using drywall and the paint I used. In my opinion drywall is a good choice as it is fire retardant, attractive and easily repaired if damaged.
mdclor
Thanks for the guidance. I will have about 3300 sq ft to cover (three times) so it will be a bit of an undertaking with a roller...
I am going with drywall because it is half of the basement and the next owners can use it for living space if they choose to do so.
Drywall primer's so inexpensive, why would you NOT use it?
Get an extension pole for the roller, and you can probably do the whole thing except the cutting in at the high corners from the floor. With an extension pole, you'll probably be faster than if you sprayed - no need to move ladders around. I still recall the first time I used an extension pole, doing a small (11x11) room with a nine-foot ceiling. Each coat, walls and ceiling, took me less than an hour, including the cutting in. I spent several days kicking myself that I'd never spent the few dollars on a pole before.
Oh, and cover the floor before you start. You could ask me how I know to do this, but your imagination will provide just as accurate an answer. Canvas painter's drop cloths aren't that expensive. In a large room, I'll paint in the direction I've got the drop cloth laid out, and move it across the room as I go. I actually own two drop cloths; I use one outside when painting the siding, and don't want to drag in the plants and dirt that it's become covered with.
Michael Wangler
Try using an 18" roller. Just make sure you use even pressure on the roller so as not to create ridges. My 18" roller with a high quality roller hold a lot of paint and covers great.
Alex Grigoriev
If anything, DO NOT use BIN drywall primer. It's crumbly chalky crap.
mdclor
More good info! I already have a pole to attach to a roller, now I just need to get an 18" roller and tray plus a couple drop cloths. I think I should be set when I get to that stage. :)
Oh, and...
Unless you're painting the ceiling white in a color that matches your hair, wear a hat. There's a reason that there are official painter's caps.
Unless you're a baldy, and you want to pretend you have short hair the color of your ceiling paint - then, don't wear one.
Get a 3/4" nap. Anything less and you'll spend more time dipping than rolling. I'm a big fan of the Purdy Colossus roller covers. Keep the roller loaded, and don't use pressure to try to get more paint out of the cover, and if you feel the roller sliding, roll over that area again until you get a slight crackling sound--then you'll have even roller stipple.
Jason
If the shop is big enough to need 3+ gallons...
John in NM
Skip the tray and get a roller screen for a 5 gallon bucket. Way easier than refilling that silly tray every time you turn around.
friend of mine was an apartment manager
Bruce, a MN Galoot
And he bought one of those Wagner power fill rollers. He said it was by far faster than any other method he tried, including spraying.
Re: friend of mine was an apartment manager
That is one of the very few positive comments I have heard on the power feed roller. Everyone I know that has tried one has said it either feeds paint painfully slowly or so fast you have to paint like a maniac to keep up.
I like to paint out of a "five" (5 gallon bucket with a screen) and a 9" roller. Painted a lot of houses that way. Lately been hiring it out to a painter with an airless sprayer. I get it ready and he paints. I really like this "Point and Pay" method of work.
If you are going to try an 18" roller you might try a mortar pan and a screen for a pain tray. the big box stores have mortar pans for about $10.
And Jason is right, use a 3/4" nap and don't skimp on the price. An excellent cover is worth every penny. You can keep it wet by leaving it submerged in the paint or by wrapping it in plastic, like a trash bag. You can refrigerate it and use it for days and days.
Here's what I use (have several, actually):
http://www.amazon.com/Wooster-Brush-BR036-18-Sherlock-Adjustable/dp/B003E478KY/ref=sr_1_4?ie=UTF8&qid=1434539091&sr=8-4&keywords=wooster+18%22+roller
Along with:
http://www.amazon.com/Wooster-Brush-8614-Gallon-Bucket/dp/B00002NCNE/ref=sr_1_13?ie=UTF8&qid=1434539232&sr=8-13&keywords=wooster+18%22+roller
The above pan has covers available. If you want to go a bit cheaper, then you can use these:
http://www.amazon.com/Wooster-Brush-BR045-18-Roller-18-Inch/dp/B0001N9YH6/ref=sr_1_1?ie=UTF8&qid=1434539293&sr=8-1&keywords=wooster+18%22+roller
http://www.amazon.com/Wooster-Brush-BR412-21-Tray-21-Inch/dp/B0001N9YDU/ref=sr_1_9?ie=UTF8&qid=1434539331&sr=8-9&keywords=wooster+18%22+roller
As for poles, these are the bee's knees:
http://www.amazon.com/Wooster-Brush-SR090-Convertible-Extension/dp/B000CSWWE2/ref=sr_1_1?ie=UTF8&qid=1434539398&sr=8-1&keywords=wooster+extension+pole
I'll use that length of pole up to about 9-10' tall walls. There are also 4-8', 6-12' (have both of those) and 8-16' versions.
It's all Wooster stuff, because they've (mostly) gotten it right. I've used many of the imitations, and, well, they mostly stink.
The roller cover I'd recommend:
http://www.amazon.com/Purdy-144630184-Colossus-18-Inch-4-Inch/dp/B0067NJZK0/ref=sr_1_1?ie=UTF8&qid=1434539556&sr=8-1&keywords=colossus+roller+cover
Jason
great stuff Jason.  thanks
mdclor
Thank you for sharing your expertise.
Re: Painting shop drywall *LINK*
walta
It looks like you will need a lot of paint.
A many cities have a paint recycler that mix and resell at low cost.
Your color could be a DIY mix from the habitat restore.
Walta
reColor
