Finished Bandsaw (long)
Seemed most every time I'd fire up the JET 18" bs the bearings would scream at me that it was time for a change. Finally, Memsahib says "I can't stand it when you turn the thing on! Get it fixed."
Memsahib hath spoken, so out comes the parts list and new sets of NTN bearings for the top and bottom wheels get ordered. Then comes time to tear the beast apart, and lo and behold, that set of wheel-pullers I bought at one of those truckload tool "auction" things about 15 years ago (but never took out of the box) are just the ticket for getting the wheels off the shafts. Being short on bearing pullers, they got pulled off the shafts with the spider things as well.
New bearings arrive but the main drive shaft requires a press to get the new bearings on so down to my friend's machine shop to use his. "This shouldn't take much, easy putt" sez I, and start to raise the press carrier table, lifting the left side to clear the next notch. Before I can pull the left pin, the carrier comes off the right side pin and crashes down. With my left hand on the left handle, the table rotates up smashing my left pinky to the frame. On to the ER and 14 stitches to sow it back on straight. ("Nice clean break" she said).
Go back to the mach shop and finish pressing on the bearings, then back home to face Memsahib Lecture No. 43. Translated as "One of these days you're gonna cut something off that they can't sow back on."
Next weekend I'm off the drugs and able to reassemble the saw. Put the blade back on and hit the switch. "Whoa, way quite" until I hit the off switch. Something starts screeching. Turns out I had 2 bad bearings in the under-table set of Carter guides. OK, so order some of those. Meanwhile I figure I'll tune up the guides, only to find that they won't center because the mount blocks don't have enough adjustment so one side's rollers are at max and the other is in the middle of its range. Tear down the top guides and take the mounting block to put on bud's bridgeport and cut the slot 1/4" deeper.
Bingo! I can now play with shims to get the blade dead center between the rollers.
If we're doing all this, may as go whole hog and get the bottom guides reset. While I'm at it, I install two pieces of 7/16" steel to raise the bottom guide set closer to the table
Two guide rollers had to be replaced, and now everything's centered and balanced so with a slight adjustment on the top wheel I do a rip of some 10/4 maple. . . . Holy Moly! This saw never cut so smoothly! Same blade but no drift or wiggle!
No squeeks, shreeks or nuthin!
I have me a new band saw! And peace in the house (It'll be nice when the finger nail grows back)
