OT Removing a dead Bolt?????
The house I bought has a double key Dead bolt. I have changed about a hundred of them over the years, but this one has two smooth heads where the screws normally are on the inside.
I picked at them a bit, but they seem solid. There must be a trick. How did they drive them to start with? I can and will drill them out, but I am curious as to how they work. Looked on Youtube, but in every case they had either Phillips heads or Allen heads. Sometimes there was a cover plate. I have two smooth brass circles starring at me. Any suggestions?
Re: OT Removing a dead Bolt?????
Kneale Brownson
Maybe take off the bolt plate on edge of door?
Jason Roehl in Lafayette, IN
Is there a slot somewhere around the perimeter of the plate, next to the door surface where you might be able to pry/pop the plate off?
Some close-up pics might be helpful...
Jason
John McGaw
Schlage lock? Some of theirs have plugs covering the buried screw heads. No idea how to get the plugs out without damaging things though.
name brand?
Dick Coers
Lots of options. Some have threaded cylinders that thread into the body of the lock, but, there is some type of holding system to keep it from turning when you don't want it to. Here's some instructions I found on U.S. Lock on a Google search;
1. Take off the plate the covers the "lock bar" - the bar that comes out of door to lock it.
2. Stick your key into the outside key hole and turn it so the "bar" comes out. You'll notice two SMALL holes on either side of it. This is where it got tricky...
3. Using a 5/64 Allen Key, I stuck it into the hole closest to the "outside" key hole. I turned it quite a few times only to realize that "nothing" was happening. Or so I thought....
4. I took the lock key and stuck it back in the key hole and started to turn it and what'a you know, the hole lock assembly turned with it, coutner clockwise. A couple more twists and the outside part of the lock came off.
5. This then revealed three (3!!!) screws on the inside of the lock holding the "insde" part of the lock in place. I unscrewed those and the "inside" part of the lock fell off the door. Then I took out the "ring" on the inside of the door and pulled the "lock bar" out of the door.
Others have a trim ring that pops off and reveals some screws.
Re: name brand?
It was an Arrow Deadbolt. (never heard of it before) Not one of the touch screen or push button one, but the old fashioned kind with a key lock on both sides. I have searched the web and Youtube again, but did not find anything useful. It appears the two things I thought were screw heads with no slots were actually lugs installed by the person who installed the lock. I drilled them out with a left hand drill bit hoping it would unscrew the screws. When it cut through the plugs it revealed Phillips screws underneath. I backed them out and the lock fell out. I trashed it and replaced it with a new one keyed to the new locks on the other doors. (I bought eighty sets of Kwikset knobs and dead bolts at a freight auction for $5 a set)
