Chimney removal
Chimney removal
Chimney removal
Howard
Thoughts on removing a forty year old triple wall metal chimney flu starting at he top. It consists of 36 inch sections that fit into each other and then are twisted to lock into
place.
Ideally I shout be able to twist in opposite direction and remove each section but junctions and bunged up with tar etc.
A friend suggested using a sazall to cut into sections but I'm nut sure how well it will work on sheet metal especially the stainless steel inner wall.
Wondering if anyone has any ideas?
Thanks
Howard
Re: Chimney removal
Re: Chimney removal
Steve Jenkins
I would start at the top and twist it and see what happens. You might get one or several sections at once. Either way just take it as it comes. Since you are taking it down I assume it is trash so you could get a metal cutting blade for your sawzall and try it. I expect it would cut.
Steve
Re: Chimney removal
Re: Chimney removal
james runchey
My son and I tore out an old hotair gravity feed furnace{from the early 1900 hundreds} which had the joints wrapped with asbestos tape. Not wanted to disturb the asbestos, we cut between the joints with an angle grinder. Worked great, didn't have to disturb the asbestos at all.
Re: Chimney removal
Re: Chimney removal
john Veerkamp
An oversized pipe strap will greatly ease the twisting. Some brands have a locking ring around the joint also. If so take them off first.
