OT Anybody Use Ozone for Odor Removal???
I bought another house that has an odor problem. Combination of tobacco and pet odors (cats). I had it scrubbed. Walls and floors, but not the ceiling. Astounding how the walls went from brown to off-white. Floors are hard wood, older worn oak with some wood exposed and some newer hickory with the "fifty year" finish.
I looked into an odor removal company and they bid $500. Were going to put an ozone generator in it over night and claimed it was like a miracle. Seemed a lot of money for a brief treatment.
Been thinking about it. I can buy a Ozone Generator for less than $500. I was thinking that if it actually works I could use it over and over and even in crawl spaces.
So, does anybody really know anything about these things and this process? Does it really knock out the odors? How long does the effect Last? Is it permanent? What does the house smell like after the treatment?
Re: OT Anybody Use Ozone for Odor Removal???
John Veerkamp
Hotels use portable ozone generators to remove pet odors between guests. For your business you might check them for a source for one, maybe even able to talk a local motel and rent one from them.
Joseph Mulherin, sr
Barry, I just did a search on the Net and came up with a company who has various models. 5yr warrantys, free shipping, and 30 day money back guarantee if not satisfied.
http://www.odorfreemachines.com
#villa1000 seems to be what you would need/ 4,000sqft/$379
John McGaw
When I worked for the Alaska Court System we had an arson fire at a local courthouse. A total mess with loads of rooms, furniture, books, equipment, etc saturated with smoke (not to mention the stuff that got water-soaked in putting out the fire). We had an out-of-state contractor come in and they used a number of techniques including ozone machines and I can say that the did manage to remove any odors that I could detect (and I have a good nose for such things). I don't know if there is any special technique involved or if it is enough to simply turn the things on in a room and wait for results. Technical Operations, where I worked, had the responsibility of getting the equipment working after the contractors did their thing in disassembling, drying and deodorizing and they weren't quite as good at the equipment handling as I'd have liked and we spent a lot of manhours getting everything operational again. At least the stuff didn't stink up the electronics shop while our techs worked on it.
ebd
ebd
I don't know about odor removal but I have a very small ionizer that I use in my shop. If I run it a while before starting work, all (and I mean even the tinest particles) dust just precipitates out of the air. When I used to smoke a pipe the smoke would drift down to the floor instead of up.
Yes and no..... *LINK*
Tim Greif - West of Chicago
I have a summer house on the river where the previous owner had converted an attached garage into a party room, complete with paneling, carpet and disco balls of all things. For some reason, that room had a very odd smell. Not musty like a moisture problem, but more a chemical type smell. We had the carpet professionally cleaned and the smell returned. I decided to pop for my own ozone generator - about $170. It helped greatly, but not enough to satisfy us for that room. We ended up tearing out the carpet and padding, as well as most of the paneling. We completely stripped the floor down to bare concrete and then power washed it. Hit it again with ozone. This was a major pain. The carpet was glued to the padding, which was glued to the concrete. We still have a hint of the odor on humid days that is probably trapped in the drywall or insulation, but it's good enough that we can now refinish the room. The ozone does a good job where it can get to the odor causing culprit. But we discovered that for it to penetrate carpet to get to the padding or below was just asking too much, at least for the one we got. I suspect to completely eliminate the odor, we might have to strip the room down to the studs and start over. Not gonna happen. We even let the ozone run for a whole week. I will say, it does a great job of killing bugs too, at that exposure. Keep in mind this is a house that was built in the 1930s and remodeled a couple times, so no telling what that chemical smell may have been caused by.
We did have very good luck with it eliminating food odors. We suffered a power outage that lasted for about a week before we discovered it. We had a fault on the incoming buried power feeder that killed power to two refrigerators full of food. Think of the smell of rotting hamburger or chicken sealed up inside a refrigerator. I figured both units were beyond hope, but since we already had an ozone generator, I thought what the heck? What a surprise. We left the fridge door open and put the generator right in front of it to blow into it for a few days. One freezer has a slight hint of vanilla ice cream that had melted and oozed all over everything. The other fridge is totally odor free. Worked like a charm on those.
Keep in mind, these things are not designed for use in an occupied house. Ozone is not good to breathe. You need to seal things up and leave the premises. The smell is - well it's like the smell of ozone. Many people associate the smell with thunderstorms. Kind of an outdoor clean odor. If you've ever smelled ozone, you'll recognize it.
Home ionizers have a similar clean smell but are really designed to electrostatically remove particulates, like dust and cigarette or cigar smoke by electrically charging them and making them stick to walls and windows. The ozone generator is a much more powerful machine.
I do know that commercial, truck mounted ozone machines are used to deodorize homes that have had flood damage to eliminate the musty smell and kill any mold issues. It is a powerful oxidant. So if the odor is organic and can be killed by an oxidant, the ozone generator will give good results. But if it's chemical in nature and not susceptible to oxidation, you'll get mixed results.
Sorry this is so long winded. For me, it was worth the $170 to use it on a number of areas. Any old home is going to have characteristic odors. It will help, but might not completely work like magic on everything.
Ozone Generator I bought.
Re: Yes and no.....
Thanks Tim and everyone else.
I rented a machine for about $90 bucks for a day. Ran it for about 18 hours. Ran in once and while and moved it from room to room. It smells better (less?) but it was not a miracle.
Had a cleaning crew go in and clean some of the walls and the floors before the Ozone treatment. That helped too,
This morning I went back and changed some locks, but while is was there I wiped down some surfaces the cleaners ignored. Amazing how much tar and nicotine I got off windows and door facings. I wiped down the outside of the front door and the glass on the storm door because I had noticed when you opened the storm door you got a whiff of the odor.
At this point, I think I will just keep scrubbing.
I looked at Tim's machine, but it is no longer available. Might be useful to have one. I have thrown away at least a half a dozen stinking fridges.
Re: Yes and no.....
Joseph Mulherin, sr
Barry, did you even look at the Odor-Free product I mentioned? They have a 30 day offer for FREE before you can purchase.
Yes I did.....
I looked a t it. the Warranty is appealing. I probably woudl have bought Tim's machine, but it is no longer available. (Just based on the fact that he actually used it and liked it.)
I was somewhat disappointed in the one I rented. I think it helped some, but not as much as I hoped.
I went in the house the other day with a giant roll of wet wipes. Was stunned at how much tar a nicotine I could still get out of the door facings and corners.
Any of you smoking should quit. This stuff is nasty.
I think I am going back with a Swiffer and go over the floors yet again. They have been mopped three times, but I am beginning to believe mopping just pushes the residue around. I talked to Stanley Steamer about steaming the hardwood and vinyl, but they wanted almost five hundred bucks. Did not seem like it was worth it, but it may have been the ticket.
Re: Yes I did.....
Joseph Mulherin, sr
OK, Barry, since the generator Tim mentioned is NOT available anymore(maybe later) then you are, in some time in the future in your housing buying and flipping, going to need an Ozone generator.Go with the one I mentioned and you will be happy.
And, INMHO, maybe covering the entire inside of the house with KILZ ...even floors and ceilings,would help in getting rid of the odors....you can repaint over it later.
