Re: Folding portable tablesaw
Jerry Gibbs
I have a 10" Ryobi with a folding stand. I like the saw and it stores compactly. It is also relatively inexpensive. The fence is surprisingly accurate, although I check it. There are two features I do not like. The miter slots are smaller than standard and have tabs at the top, apparently to keep the cheap miter gauge from falling out. Since the gauge is sloppy (I never expected much) I made a cut-off sled. Trying to make runners to fit those odd slots proved too difficult. I cut the tabs off. The other problem is the blade insert. It is stamped sheet steel of an odd configuration. I found it impossible to replace it with a solid insert for zero clearance. I use a large piece of plastic laminate covering the blade slot to provide the zero clearance. The laminate piece is large so it can be clamped on the end, a perfect use for the laminate you saved but don't know what to do with.
I would buy this saw again. It is used at our FL trailer and space is an issue. The saw cuts well and stores easily, along with the folding stand. I never tried dust collection. Given that dust collection on a full size saw with a real dust collector is difficult, I wonder how successful you would be. Jerry
