confused
tom sontag - st. louis
Your last paragraph did not register very well in my brain. I dissect it below:
--There is a misconception that endgrain joints are weaker than sidegrain joints, this isn't true. What is true is that you can get full strength in a sidegrain joint, but only a minimal percent of strength in endgrain joints.
Those two sentences seem to say opposite things. Isn't a joint with "only a minimal percent of strength" weaker than a full strength one?
--But that has more to do with the ease with which sidegrain splits.
Let's keep the discussion on the JOINT, not the nearby wood
--If you glue endgrain to sidegrain, it will still break outside the glue joint, just as it does with sidegrain to sidegrain.
I am tempted to test this. I'll take your word for now.
--But the 0 axis is what carries heavy loads,
?? Help!
--and it would be nice if we could just glue stuff end to end.
Amen brother.
