Powermatic Extension Tables
I'm looking at ordering a Powermatic 2000 table saw with 50" extension. The 5hp 1PH model comes in a couple of flavors. One has a workbench top and tail vise for the extension. The other has a built in router lift and router fence.
Okay, so I know it's all a matter of preference. I have a router table. It's a Bench Dog. But has anyone found any advantages of a router in their saw extension instead of a conventional router table?
Thanks.
T
Re: Powermatic Extension Tables
A.J. Hamler
A.J. Hamler
I love having my router in the table saw extension. The thing of it is, is that a table saw extension is already a permanent part of the landscape, but a separate router table adds a second piece of equipment to the shop that, when not used for what it is, is simply in the way. By having the router in the extension, you can eliminate a floorspace-eating second piece of equipment.
The other advantage is that having the extension become a router table means you have a much, much bigger router table. Typical router tables are, what, 24" x 30" or thereabouts? By considering the entire top of my table saw as a router table when needed, my router table is effectively huge, with nearly unlimited support for even the largest workpieces I might need to rout.
And with my outfeed/assembly table at the same height as the saw and extension, the real estate available to routing is even larger.
A.J.
I don't have this model, but do have routers
Keith Newton
in the wing of my old #72. It has a solid cast iron wing, which I cut 3 router holes into. I've only needed 3 routers set up at once a few times, so most of the time, only one is mounted. I think it is an excellent place for a table router.
Most of the time when I would need a table router, I would be working solids, which don't need the saw fence as far over to compete for space as when I'm working with sheet goods, so it saves floor space by doing double duty.
As for the vice, it looks like about $500 to add it on. I'm pretty sure I can build a nice workbench catch table with a better vice mounted on it for less than that. But it may be perfect for some.
Otherwise, I think you should be happy with that saw.
Good points, all. Thanks. If I buy it, you wanna buy my old router table? ;-)
Here
I have occasionally found it handy to have effectively two router tables, one on saw one on router table, translating to two sets ups. I cannot recall specific bit combinations I have sued this way but I do recall the convenience.
