I bought some tunes from ITunes and burned a CD. The CD worked fine on our Bose CD player and on the CD player in our 2008 Volvo; but the CD player in our 1996 Volvo rejects it. This CD player has no trouble playing commercial discs. Is there some security code on discs burned from ITunes that confuses older CD players? Should I just try burning another disc?
You can always burn some other music from a different source to CD to test the blanks and burning process and player. This will eliminate the 'security code' question although I'm virtually certain that this is not in the running as a cause.
Given the price of blank CDs I'd try again. If you have been using the eraseable type or some off-brand then I'd switch over to the one-time write type from a good brand (I swear by Taiyo Yuden and won't use anything else). If your burning software allows it, tell it to burn more slowly than the theoretical max speed and to verify the burn afterward.
I'd bet dollars to doughnuts you burned that CD with a bunch of mp3 files. The mp3 standard was only released in 1995, and if memory serves, it was not standard for CD players to be able to read mp3 files (data) until several years later.
If you were to burn the CD as an audio CD, containing only about 74 minutes of audio (and full), it would probably work in the player.
Yeah, I remember buying a car in the late 90's where the sales literature made a big deal about "plays your MP3 files." I thought that was the best thing since sliced bread.
Unfortunately, besides the audio system, the rest of the car was a big disappointment, and I suspect they added a few hundred dollars to the price of that car for the mp3 player.
I think the more recent approach of using bluetooth to reach out to phones and other devices makes a lot more sense. The design cycle for cars is way longer than for cutting edge electronics, they will never to up to date. Just let the phone do the creative part and send the result to the car over a simple, standard interface.
.wav probably still won't work--the point is that the older CD players read a continuous uncompressed data stream, using a table-of-contents to point to the beginning of each track, if not played through continuously. I don't think it was until about '98-'00 when CD players could generally read different audio file formats, compressed or not.
Here is a link that shows you how to make an audio CD from MP3 files. I've never used it but the general info in it should get you pointed in the right direction even if you need to use a different program.
