Delta 31-352 1" sander
Steven Antonucci
steven antonucci
Anyone know where you can find replacement parts for one of these?
I inherited one a week ago, and in a week, it's had two wheels explode from dry rot. Still haven't found all the plastic. I "bush fixed it" with a turned wooden wheel, but it isn't running that great.
Google didn't get me very far...
Steve
Re: Delta 31-352 1" sander
Bob Entwisle in NJ
Hi Steven,
I found these links when I googled "Delta 31-352"
http://www.toolpartsdirect.com/delta-31-352-1-quot-sander-grinder.html
http://www.ereplacementparts.com/delta-31352-type-134-sandergrinder-parts-c-3275_3621_12772.html
http://www.mikestools.com/delta-abrasive-sanding-machines-parts-lists_2275.aspx
Hope the links help, good luck!
Bob in NJ
Steven Antonucci
Thanks, but
steven antonucci
already found them, and unfortunately, the parts I need are "Obsolete, no replacement"
I will just have to stick with my wooden wheel I suppose?
Steve
Re: Thanks, but - Which parts do you need?
Bob Entwisle in NJ
Well, which parts are you looking for?
I found a drive pulley here:
http://stores.renovoparts.com/926-11-991-9441-pulley/
What else?
Bob in NJ
Gary Smyth
Find this guy Jim Liechty. last email is jimliechty@yahoo.com. (May 2013). He makes the wheels. A full set was $83 and change and given my use worth every penny. The machine now sell for over $400, and some $500. The wheels have a crown which is why turned wheels don't run well. Also the 2" idler wheel is a press fit and might be a bit of work.
I have no record of where (ebay perhaps). He even includes directions. I bought two years ago and run the sander often. I hope that you can find him he can get you in line.
UPDATE: There is a Jim Liechty listed in "Vintage Machinery site. It may be the correct person. There are others on Google so explore.. Good luck
ChuckInND
I have the same model of sander and the two idler wheels are cracked, yesterday one of the idler wheels went flying off. To replace them both is over $60, I haven't decided weather I should try to glue them with PVC glue, bite the bullet and order the parts, or just sell it. I'm not very happy with Delta after the sellout.
Re: Delta 31-352 1" sander fixed
ChuckInND
I put my thinking cap on and I'm pleased to announce that I got one wheel fixed with no glue involved, and I'm headed back out to fix the other.
