Ripping on the table saw
Joe in a Cleveland suburb
Bill's Spice Box prompted this question. I was going to post this as a reply to Bill's most recent Spice box update, but didn't want to hijack his thread.
I've been using a table/cabinet saw for 20+ years now and one operation that still makes me nervous is ripping. More and more I try to do all the ripping I can on the bandsaw. Sometimes of course, it doesn't make sense to.
Bill shows ripping off the molded pieces of stock from the wider board once routed. This past weekend I ripped 6 1"X12"X6' #2 pine boards into 2" wide boards (making pickets for my wife's garden fence). On two occasions the board warped so bad while ripping it pinched the blade and I had to shut the saw off. On more than one occasion knots shot off like bullets.
I always try to be safe. I use a Bessy splitter with pawls, a big push stick, and feather boards all when I can. I always stand clear of kick backed projectiles as much as possible. I believe my saw and rip fence are tuned/set up properly to avoid pinching the stock between the blade and rip fence. I admittedly don't use a blade guard. I use/have an out feed table attached to the saw. The blade height I tend to keep high enough so the gullets are exposed.
I am left handed. But I am never sure if I should be pushing the stock through with my left or right hand. When I used to play baseball as a kid, I could bat left or right handed - either way felt natural (never could hit the damn ball though...). Same with pushing the stock through in regards to left vs. right handed.
I tend to stand left of the blade and push with my right hand (using a push stick). That doesn't seem safe as my hand/arm passes over the blade. If I stand to the right of the blade and push with my left hand, I feel as though the pushing motion might actually be pushing the stock to the left a little too.
So, I was going to ask Bill these questions in his post, but thought I'd ask everybody -
When you rip on the table saw:
Just curious I guess as to what some of you do regarding ripping safely (especially narrow stock) and how you handle safety concerns.
Thanks for any replies.
