Another Mexican food question???
My son went to a local Mexican Grocery and bought cheese to make cheese dip. He/We wanted some sort of white cheese to make gooey Dip. Tried warming it in milk with a little butter. Never could get them to mix. The cheese became soft and VERY stretchy. Could easily string it out two or three feet. When it cooled of it became tough and leathery. Delicious, but sort of unappetizing.
Anybody got a solution? Recipe? Exactly what cheese do we buy?
Re: Another Mexican food question???
Dustmaker Mike
Well what I do is. I get the white Velveeta and Rotel and use that for a spicy dip. 4OZ of Velveeta and one can of the spicy Rotel works great. Chunk the Velveeta and melt in microwave for 2 minutes. Add the Rotel and finish heating until melted. Let it cool and dip away.
Rum
Cheese melting is complex. There are several ways to make milk form curds, the two most common are rennet and acid (lemon juice, vinegar, etc..). Often the acid formed cheeses won't melt very well, whereas rennet formed ones will (there are exceptions to this of course). The actual answer involves the PH of curd formation, the rennet vs acid is simply a convenient stand in for the more complex discussion.
A good example of this is mozzerella vs Ricotta, they're interesting because you can make them from the same "batch" of milk, the mozzerella is taken off as rennet based curds first and they you can coagulate some more protiens and double down to get ricotta out of the same batch of whey (its also a nice party trick if your guests have a long attention span). Mozzerella melts wonderfully and ricotta does not (as noted there are some cheeses that overlap this convenient distinction so don't beat me up to hard on that).
What you got was likely a form of Queso Cotija, some more information here:
http://www.cheese.com/cotija/
It doesn't melt but does toast and brown deliciously. Cotija is initially rennet formed curds but also adds a bacteria culture which changes (dropps) the PH and makes it non melty.
Knowing which is which mostly involves knowing the specific cheeses and reading the labels unforunately, I don't know of an easy way to tell which is which.
Some overview of which south of the border (not just mexico) cheese are used for what here:
http://www.epicurious.com/archive/holidays/cincodemayo/mexican-cheeses
Don't feel stuck on mexican cheeses though, the gooey dip isn't really all that "mexican" and most are made with american or monterey jack cheeses :D
W use "Jack" with success. However, the Mex store should be able to advise you to a "melting" cheese.
Jesse Cloud
"rum" is right, "queso" is more tex-mex than mexican. Velveeta and Rotel well do you proud!
By the way, anything that has cheddar on it - not Mexican!
