Spice box molding
PIC 1
The bottom of the spice box has a bead and cover molding. I have a router bit that cuts this pattern, tried it and the result was not quite right. For reasons I can not put into words the effect of a two piece bead and cove molding looked better on this style box.
Making slender molding is a problem. The profile must be milled on something straight and level for the pattern to be uniform. To accomplish this feat the profile is milled on a larger piece of lumber. In the case at hand I milled the cove on a piece 3/4" thick and 2" wide.
PIC 2
PIC 3
Then I planed the board with a cove on each edge to a heavy 3/8" and ripped the 1/4 x 3/8" coves off the wider board. My preferred 40T 7 1/2" blade is so much better for cutting these small pieces ( and bigger ones too).
PIC 4
The profile was refined with a scraper made from the end of a bow saw blade.
In another post I hope to engage in a discussion of how to best wrap molding around a case and get nice tight miters.
