Waterstone Question
Tom
Someone used my 4000 grit water stone and I now see a number od scratches/ tiny grooves in the face of the stone. What is the best way to eliminate the?
Thanks!!
From now on no one will use my stones!! Except me!
Waterstone Question
Tom
Thanks!!
Re: Waterstone Question
Chuck in Mtl.
could you resurface the stone with some fine emery paper?
No harm done
Neal in San Jose
If you wander over to the hand tool side and ask this question, you will get more responses. Short answer is that water stones are soft and easy to scratch and gouge, but this doesn't usually cause any problems with use. They also wear in the areas you are using, usually the center, which does cause problems. Thus, they require frequent flattening. This can be done in several ways, but you probably already have a stash of sandpaper, so that's where I'd start. The flattening can be done wet or dry, your choice. Try a medium to fine paper on a very flat surface (a spare piece of glass works very well) and move up or down in grits based on your results. Any scratches or gouges will be removed while you flatten. HTH Neal
Re: Waterstone Question *LINK*
I got a Norton flattening stone - works quite well.
Before I got that, I used a flat piece of plate glass and sprinkled some silicon carbide abrasive grit on the glass and some water. A few "laps" and it smooths the stones quire nicely.
Silicon Carbide Grit
Archie England
IMO it's caused by the drying conditions (being out in the sun, or left damp, or etc.). Like others have said, this layer sheds with flattening, and I've never seen it make a difference in how my stones performed.
For me, it's the chips, cracks, or breaks that cause me to be stingy with my quality waterstones.
