finish for oars
finish for oars
Jack Guzman from Maine
finish for oars
I just sanded down a pair of dried out oars for a friend's rowboat.I was planning on putting a couple coats of spar varnish on them. Is this a good idea? Any other suggestions?---Jack
Re: finish for oars
Re: finish for oars
I use spar varnish except on the handles where I use linseed oil
Re: finish for oars
Re: finish for oars
Alan Hollar
Spar and marine varnishes work well, but are meant to be sanded and recoated periodically. The oil would need to be reapplied frequently as well. At least yearly I would think
Re: finish for oars
Re: finish for oars
Thanks Bill. That's all I needed to hear. I assume you oil the handles to make it easier on your hands when in use.These oars have rubber handles.---Jack
Re: finish for oars
Re: finish for oars
Correct something about oil on wood that is nice to working hands.
Re: finish for oars
Another Idea
paul woolson
I do a lot of canoe paddles as my girls are big BW, Quetico adventurers. These are slightly different because they take a bit more impact that oars do but here's my method.
I thin west system's epoxy with alcohol to make kind of a wash. Paint it on and let it soak in. If there are any "dry" areas (where it soaked in to the point that there is none on the surface), I'll hit it again until the whole thing is a uniform sheen. Let it all dry, scuff sand with 220 and hit it with a couple of coats of Spar varnish. It's worked very well for the canoe paddles. Might be worth a try on oars too.
Re: finish for oars
Re: Another Idea
Sounds like a good rugged finish. I won't go that far with these though. Just a couple coats of spar.---Jack
Re: finish for oars
Re: for hands
TomD
The trick for hands is that you use oil if the wood and situation allows, where the grip will stay dry. If the grip is normally wet, spar varnish that has been cut with water to 320 will be better. Spar varnish causes blisters where it is left smooth. If you knock the gloss off it won't last as long. So on a typical paddle (been making laminated bent shafts since the 70s) I like the place where my hand most goes to be gloss cut back where the hand falls. I leave the rest of the shaft glossy and try to make the transition look intended. The top grip I oil. But on something where I switch a lot, or for whitewater, I would do it all in gloss, and cut it back. Or to be more truthful these days I buy both WW and Switch paddles, carbon where I can afford it. I still make wooden style paddles.
Spar varnish is best for solid wood of any size. Laminations are probably going to hold up better if they are epoxied first, then coated with varnish. Most of my experience is with Zspar Captain's but there are more modern alternatives.
