How to thin Watco?
How to thin Watco?
How to thin Watco?
Bruce, a MN Galoot
I have a can of Watco that is 15-20 years old, and while it still works, it is the consistency of motor oil. Does anyone know how to thin it? I wouldn't bother but the can is nearly full.
Re: How to thin Watco?
How do you know it still "works"?
Dick Coers
I guess I would use Naptha, but I sure wouldn't use that old of material on a project that I put a lot of effort into.
We have one of those at work....
John in NM
I love the stuff once it gets that thick, it works better as a kind of wiping varnish than thinned out poly ever does.
I would bet you can thin it with any good grade mineral spirits, etc, but it's still going to tend to skin over and other stuff that Watco doesn't normally do. While I like it's properties better than fresh Watco, if the behavior of fresh stuff is what you are after, it's best to just buy some fresh.
Re: How do you know it still "works"?
Bruce, a MN Galoot
It skins over in a plastic tub, but four days after the second coat it sure acts like it is curing. I would like it thinner so it can absorb into the wood better. This particular project isn't a showcase, mostly an experiment in box-making to see how well a process works.
Re: We have one of those at work....
Bruce, a MN Galoot
Right now it's a little thicker than Minwax wiping varnish. I like it better than a wiping varnish because I put it on and rub it in with W/D sandpaper. The result is very silky.
Why it's thick
It is thick because it has begun to "cure" (polymerize). For an equal weight of stuff a polymer thickens a solution vastly more than small molecules. For example a bit of starch dissolved in water makes gravy.
Add more solvent. I suppose the solvent for this stuff is mineral spirits like most varnishes.
Richard McComas
Watco MSDS
http://www.rustoleum.com/MSDS/ENGLISH/65751.PDF
Should thin nicely then...
John in NM
Sounds like you've found just what I have found - after 15 years of waiting the stuff makes a terrific stand oil :D
Thin with Naptha or mineral spirits then, or perhaps turp if you like the smell (I do). It should soak in better and require more coats for a varnish, but it will still build to some degree, which I never found factory fresh Watco to do easily.
the nice thing about polymer viscosity
The solution viscosity of a polymer is not linear with concentration. That is to say that if you dilute a polymer solution (like your Watco) 1:1 the viscosity will not go down by half. It will go down by more, maybe way more like 4 or 8 times less depending on the details of the polymer shape in solution. I don't know what shape Watco is in solution so can't guess the viscosity reduction but it will be more than 1:1 .
This property is good. It means you can dilute a thick finish to lessen viscosity without loosing the solids concentration. It is good going to other way too. When the solvent begins to evaporate from lacquer the viscosity builds rapidly and mitigates runs.
