Stihl chainsaw problem
KEITH REINKE
I have a Stihl 280 chain saw and the problem is that when I try to cut up with it , it stops. It will work fine when cutting down but when I try to make an under cut it stops. It will also stay running at high speed for a second or so before it slows down when the trigger is released. I also had it to the dealer and they re-built the carburator but that didn't help. Any thoughts?
Re: Stihl chainsaw problem
Likely a cracked fuel hose inside tank
Dick Coers
And it will suck air if crack is not under fuel.
